Clutch assist spring
  • 5 months later...
When I fitted the standard clutch spring of this variety, I put the spring in a vice to compress it and then added two cable ties each side to hold it.
I then offered up into place and started cutting the cable ties until it popped into place.
I haven't had experience with this new stronger spring though.
Steve
  • 3 months later...
  • 4 weeks later...
On 10/13/2019 at 6:22 AM, cackshifter said:
If you have adequate vocabulary, the dexterity of a brain surgeon and the strength of king Kong you can do it in situ. If you take the clutch pedal box out it's easy to do on the bench, but then you have to bleed the clutch, and there is more work overall.
You can take the pedal box out while leaving the master cylinder connected in the engine bay.
