The V8 Porn Rebuild Thread
Bit of shotblasting with new Blaster cabinet at Home,
some painting an clamping on the mill with superfine cut and ultra low speed
and a bit of repairing, some bungs made, holes taped and its Blinged a bit
Innit :P
post-22-0-09107000-1302022769_thumb.jpg post-22-0-97326000-1302022808_thumb.jpg
Being even sader <anorak out and rustling mode> its "Eales Blue <sad mode off> :P
And also todays aquisition, a lump of 4.5" Truck exhaust to have a go at the MK1 Air trumpet joiner
which will see a flurry of fabrication time which may (Or may not :lol: ) work
Nige
<slap awaiting mode>Are you gonna clean that plenum or not bother?</slap awaiting mode> :ph34r:
Looking good Nige, I bet after all this time you really do need to hear it run very soon....
Hmmm, thought about making the airbox thingumy out of clear perspex...? Nothing like looking at three chokes opening all at the same time :ph34r:
Moving forwards now
With bits from Monsewer Gibbon here on LR4x4, and my trusty cleaning tank with BS666
'disolve skin bone & tissue' "Organic" cleaning fluid :) I sent the cleaned serp 3.9 dizzy stylee front end to
John for "JED tweaking", including converting to Remote oil filter / thermostat, new gears, and other tweaks, now
back ...so update soon(ish) when cuddling it has finished :moglite:
post-22-0-74659000-1302557227_thumb.jpg post-22-0-40689000-1302557334_thumb.jpg
Top is oil in, Bottom is oil out :)
Mr Gibbon may be along to confirm 'on delivery' to moi, it was not 'quite' this clean :lol:
This is what John said SHOULD have been on it, was when it was built, was then bodgificated, and then
on me getting it sorted with Johns help to what was originally on there.
Anyone want to buy a wierdly modified Thor Timing cover, tweaked by "Mongo" from blazing saddles fame ? :D
(well looks like his work :lol: )
Nige
  • 4 weeks later...
Oh God don't :(
Spent an inorinate amount of time on the issue of the front cover and front end, spent no less
than 10 hours this weekend getting nowhere with bits that should fit that don't, learnt a lot,
some about V8s and the changes between model years and also not to maybe buy engines fully stripped
in boxes.
Update and pics later
Nige
When all said and done, ask yourself 'Would I do it again?' And then you know it is worth it or not... :)
All this for an extra ~ 50BHP, might as well have chucked a beetle engine in the back, flat four, should fit between the wheelboxes :ph34r:
Nige,
If I send the rest of it to you, will you clean it just as well for me!!!!!!??????
Keep up the good work, i'm enjoying watching this frankenstein come together :blink::rolleyes:
Well you **********s I have been a cleaning and a grumping today and have cleaned all
the bits from a 4.0 Serp Short Timing Cover V8 fropm Grant on this forum (which I bought for "Prototyping work" for megasquirt
(Thats that firework well and truly Pi**ed On) as its now in bits, and is a long motor that looks like its been raped (well, it has)
Grants 4.0 Front end, will, with a bit of luck, 14 litres of superglue and some hammering be going on the front end
of the eales. May even keep the A/C pump for an on board air version - need to see what it clouts on fitting.
Should have some pics by the weekend, hoping to shove it built into the 90 and have it working 1/ 2nd week june :)
Mut go, SWMBO has put beer in my padded cell, so screaming calleth :D
Nige
PS White, - I know where you live and have a spade :P
Nige
Nige,
Is the superglue, for sticking your body together again after you have clouted yourself rather than the engine?? :P
Hat.....
Coat.....
Gone!!!
PS, hope you didn't spill too much beer in the padded cell.
Sweet God almighty
More greif, bits mismatched like oil pick up pipe to sump, sump to timing cover and other
Grrr moments, but as I type tonight - knackered havehad a great indian takeaway with mate helping me,
and about to have a skinfull of 1664 :D the engine sits with most of it built, and we think the rest should now be straight
forward :ph34r: but gawd I feel hugely unsure of even touching it tommorrow even less doing anything to it
being its going to be Friday 13th :blink:
Might take pics - that has to be sfae doesn't it ?
Nearly nealy there, fitting is 1st week June as SWMBO is away and I can spend unlimted time in the workshop and unlimited
£s with delivered Takeaways :)
Nige
