simonr Posted April 10, 2012 Author Share Posted April 10, 2012 I might reserve X-Andbacon for something else! Very funny! Si Quote Link to comment Share on other sites More sharing options...
KKMobile Posted April 10, 2012 Share Posted April 10, 2012 Looks good!! How about simply the X Lock Range?? Kev Quote Link to comment Share on other sites More sharing options...
muddy Posted April 10, 2012 Share Posted April 10, 2012 Apologies if it's been said X-amour range X-shield (ignition barrel) X-jam (gear lever lock) X-flap (pedals) I like X and bacon or how about X-asperating ( for the thief ) Will. Quote Link to comment Share on other sites More sharing options...
Cliff Pountney Posted April 10, 2012 Share Posted April 10, 2012 The Xxx would get you plenty of hits from search engines but maybe not many sales. I think sercurity needs a two stage approach. Something really obvious as a sign like your product then something difficult to detect probably in the engine wiring harness. Cliff Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 10, 2012 Share Posted April 10, 2012 X-Press - because you can't press the pedal .....when you've got the metal! Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted April 10, 2012 Share Posted April 10, 2012 get rid of your pikey problem with the X-ORCIST! Quote Link to comment Share on other sites More sharing options...
Big.Mike Posted April 10, 2012 Share Posted April 10, 2012 X-Safe, X-S Pedal, X-Tra Safe, X-Cover? Humbly, I wouldn't worry about how long it takes to get through it anything more than a minute is enough of a deterrent. It's more about how much noise it takes to remove and critically how obvious it is in the vehicle. Would it be worth coming up with some large window stickers just to make clear that it's there? Ta, Mike Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted April 10, 2012 Share Posted April 10, 2012 X-Blocks or X-Blox I think that thats the best so far, maybe X-Block Gear/Pedal/Ignition etc. Blox being the prefered version, most will remember that name easily. Quote Link to comment Share on other sites More sharing options...
muttleyd Posted April 10, 2012 Share Posted April 10, 2012 A proper job, well considered and cleverly engineered. X-stop X-off X-guard Keep the great products coming... Quote Link to comment Share on other sites More sharing options...
bishbosh Posted April 10, 2012 Share Posted April 10, 2012 Xquizit Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 10, 2012 Share Posted April 10, 2012 you could re-brand your ground anchor as the X-Hume.. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 10, 2012 Share Posted April 10, 2012 another one for the pedal guard: x-asperate Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 10, 2012 Share Posted April 10, 2012 a window tinting kit called X-Tint ? Quote Link to comment Share on other sites More sharing options...
Ozyboy Posted April 10, 2012 Share Posted April 10, 2012 X-Defend X-Defender Quote Link to comment Share on other sites More sharing options...
ballcock Posted April 10, 2012 Share Posted April 10, 2012 How about X-Pert range. ( X-PERT pedal lock, x-pert gear lock) Shows how much attention you put into the detail, looks good all the best with it's sales and hope it makes a significant dent in the defender thefts. Quote Link to comment Share on other sites More sharing options...
muddy Posted April 11, 2012 Share Posted April 11, 2012 The X-truder range, intruders don't bother when you've got one of these! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 11, 2012 Share Posted April 11, 2012 X-Calibur Quote Link to comment Share on other sites More sharing options...
Superpants Posted April 11, 2012 Share Posted April 11, 2012 X-Terminate or X-Terminator ? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 11, 2012 Share Posted April 11, 2012 Thoughts from the deep recesses of my little warped mind X-Acerbate X-Pert-Witness X-Clude X-Spell X-Hibit X-Intruder X-E-no-time (look it up ) Nige Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 11, 2012 Share Posted April 11, 2012 As a mere female Simon that is fantastic ! Even I would have no problem using it - once hubbie had fitted it!!!! Margaret (mrsgemini) Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted April 11, 2012 Share Posted April 11, 2012 anything in the pipeline for us proper land rover owners?? my 2a wouldn't mind having one there Quote Link to comment Share on other sites More sharing options...
discomikey Posted April 11, 2012 Share Posted April 11, 2012 just imagine how annoyed the thief would be if he spent ages trying to get past this, only to open it and find another kind of pedal lock in there like a clutch claw etc. (not in any way incinuating that product is any better than yours si) just pointing out the oppotrunitys for the "layered anti theft" obviously would only be needed if you parked overnight somewhere dodgy. (like liverpool) Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted April 11, 2012 Share Posted April 11, 2012 The X-ist range ... because when you come back to your truck it will still exist thanks to these locks Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 11, 2012 Share Posted April 11, 2012 X-It Because when you exit the vehicle you lock it, to secure it, Quote Link to comment Share on other sites More sharing options...
