Daan Posted September 4, 2022 Share Posted September 4, 2022 On 8/18/2022 at 3:13 PM, Stellaghost said: regards Stephen I have a slight concern with this arrangement: you have essentially created 2 joints close to each other, which would want to move upwards when a you get big hit on the front wheels. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted September 4, 2022 Share Posted September 4, 2022 7 minutes ago, Daan said: I have a slight concern with this arrangement: you have essentially created 2 joints close to each other, which would want to move upwards when a you get big hit on the front wheels. I also thought this, and thought of the simple solution to weld tabs onto the cross member either side of the clevis with a slot, rather than a hole. This would allow in and out cushioning of the bush but restrict the dogleg situation that probably would Occour with the leverage from the portals. Sorry for not mentioning sooner Stephen, I got distracted mid reply and forgot Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 4, 2022 Author Share Posted September 4, 2022 32 minutes ago, Daan said: I have a slight concern with this arrangement: you have essentially created 2 joints close to each other, which would want to move upwards when a you get big hit on the front wheels. 25 minutes ago, dangerous doug said: I also thought this, and thought of the simple solution to weld tabs onto the cross member either side of the clevis with a slot, rather than a hole. This would allow in and out cushioning of the bush but restrict the dogleg situation that probably would Occour with the leverage from the portals. Sorry for not mentioning sooner Stephen, I got distracted mid reply and forgot Thanks for the reply guys, but I'll stick with my plan for now, believe me these bushes are immensely strong and I have no concerns whatsoever about creating a dogleg effect, however if I'm proven wrong then it's only some additional fabrication at the end of the day regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted September 6, 2022 Share Posted September 6, 2022 @Stellaghost what diameter are your shocks? what size bolt are you using through the spherical bearings? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 6, 2022 Author Share Posted September 6, 2022 38 minutes ago, RedLineMike said: @Stellaghost what diameter are your shocks? what size bolt are you using through the spherical bearings? Shocks are 2" diameter 7 /8" shafts and bolt through spherical is 1 /2" regards Stephen Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 7, 2022 Share Posted September 7, 2022 I didn’t realise you’d bought imperial shocks ! Makes sense for them to fit an old Land Rover though of course 😊 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 7, 2022 Share Posted September 7, 2022 Most of these rod ends etc are all imperial -in fact difficult to get in metric at all.... Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 7, 2022 Author Share Posted September 7, 2022 21 minutes ago, Anderzander said: I didn’t realise you’d bought imperial shocks ! Makes sense for them to fit an old Land Rover though of course 😊 11 minutes ago, Bowie69 said: Most of these rod ends etc are all imperial -in fact difficult to get in metric at all.... Problem is Fox are American and America still uses imperial measurements, it isn't an issue considering everything has to be made bespoke to fit it all together anyway regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 7, 2022 Author Share Posted September 7, 2022 38 minutes ago, Anderzander said: for them to fit an old Land Rover though of course That depends upon your perspective..... 70% of Sid is brand new .....lol Regards Stephen 1 2 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 7, 2022 Share Posted September 7, 2022 And by weight 70% of Sid is Mercedes ! 😀 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 7, 2022 Share Posted September 7, 2022 “oh lord won’t you buy me a Mercedes’ Benz, my friends are all driving land rovers, and I must make amends !” 1 1 Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted September 8, 2022 Share Posted September 8, 2022 On 9/6/2022 at 12:15 PM, Stellaghost said: Shocks are 2" diameter 7 /8" shafts and bolt through spherical is 1 /2" regards Stephen i thought they were 2.5"s for some reason, reason for asking is on the bigger shocks they have a slightly bigger spherical bearing on the ends, which use a step down reducer which gives more missalignment that the normal parallel spacers which would have helped your misalignment, but not in this case Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted September 10, 2022 Author Popular Post Share Posted September 10, 2022 Busy day today trying to get ready for some suspension cycling, just didn't get there too tired on the back of nightshift Just need to fit pan hard rod then might be able to start Did get single link nearly completed although still requiring some bracing and blending Cushion joint compressed, very very tight Some technical tying for single link set up Some pipe shaping One completed set of antlers Fitted Front shock positions need slightly altering regards Stephen 6 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 11, 2022 Author Share Posted September 11, 2022 Pan hard rod fitted this morning and another job to fine tune, steering arm I made needs a slight adjustment I then decide to lift a rear wheel, not enough weight to give suspension a workout will need to put engine and box back on Flex not looking too bad at the moment and still plenty of scope on Cushion joint thoughts as always appreciated regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
steve b Posted September 11, 2022 Share Posted September 11, 2022 Looking good , can you make the panhard rod any longer ? Steve Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 11, 2022 Author Share Posted September 11, 2022 Just now, steve b said: Looking good , can you make the panhard rod any longer ? Steve I probably could or buy an adjustable one, but as it sits at the moment chassis is in the right position with regards to axles, would a longer one not effect positioning at rest regards Stephen Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 11, 2022 Share Posted September 11, 2022 24 minutes ago, Stellaghost said: I probably could or buy an adjustable one, but as it sits at the moment chassis is in the right position with regards to axles, would a longer one not effect positioning at rest regards Stephen It's good for panhards to be long and level at rest (with mounts to suit). But also parallel to the drag link. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 11, 2022 Author Share Posted September 11, 2022 2 minutes ago, landroversforever said: It's good for panhards to be long and level at rest (with mounts to suit). But also parallel to the drag link. Once the engine and box are sat back on the pan hard will be level, axle tube is still in the same position as original rover axle, lift is caused by portal boxes regards Stephen Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted September 11, 2022 Share Posted September 11, 2022 6 hours ago, Stellaghost said: I probably could or buy an adjustable one, but as it sits at the moment chassis is in the right position with regards to axles, would a longer one not effect positioning at rest regards Stephen I've got a surplus to requirements (pretty much brand spanking new) heavy duty adjustable one here you can have for nowt Stephen. 1 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted September 11, 2022 Share Posted September 11, 2022 My point about the length is related to changing the axle position control from standard hockey sticks to the single link with a central pivot point along with much greater wheel vertical travel . If there is space and there would seem to be , then a longer link further out to the swivel on the axle and further outboard of the chassis rail would give less horizontal movement for the much larger vertical travel . If you see what I mean ? Steve Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 11, 2022 Share Posted September 11, 2022 12 minutes ago, steve b said: My point about the length is related to changing the axle position control from standard hockey sticks to the single link with a central pivot point along with much greater wheel vertical travel . If there is space and there would seem to be , then a longer link further out to the swivel on the axle and further outboard of the chassis rail would give less horizontal movement for the much larger vertical travel . If you see what I mean ? Steve The travel won’t make that much of a difference to it IMO. More important to keep the relationship to the drag link. Big vertical changes where the whole axle moved up or down sides together it would be more important. It effectively just pivots about one end or the other depending on which way it articulates for the extremes of travel. Quote Link to comment Share on other sites More sharing options...
steve b Posted September 11, 2022 Share Posted September 11, 2022 Never mind... Quote Link to comment Share on other sites More sharing options...
Wytze Posted September 11, 2022 Share Posted September 11, 2022 58 minutes ago, steve b said: My point about the length is related to changing the axle position control from standard hockey sticks to the single link with a central pivot point along with much greater wheel vertical travel . If there is space and there would seem to be , then a longer link further out to the swivel on the axle and further outboard of the chassis rail would give less horizontal movement for the much larger vertical travel . If you see what I mean ? Steve The drag link ball joint will be something to look at to, i think? Not to stress it at weird angle's? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 12, 2022 Author Share Posted September 12, 2022 12 hours ago, steve b said: My point about the length is related to changing the axle position control from standard hockey sticks to the single link with a central pivot point along with much greater wheel vertical travel . If there is space and there would seem to be , then a longer link further out to the swivel on the axle and further outboard of the chassis rail would give less horizontal movement for the much larger vertical travel . If you see what I mean ? Steve I get where your going with that how much more length does an adjustable pan hard rod give or are we talking custom made ?? Regards Stephen Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted September 12, 2022 Share Posted September 12, 2022 It will give as much length as it’s got. The adjustable ones are not to give more length for flex, they are to centre the front axle after lifting the car. Unfortunately you’re stuck with the length unless you chop about and move mounts. Everything is a compromise, and while it may not be ideal for for maximum movement, you have a bolt on arrangement right now, with aftermarket parts available and all the steering all lines up in the way it was designed….ish. what I will say though, is a 1” Jonny joint or a rose joint would be a good idea given how much movement you will have 2 Quote Link to comment Share on other sites More sharing options...
