Want to make some inner arch protectors - ideas please
To stop mud getting up on the outriggers and other places such as the rear cross member. I want to make some shields/guards up. Should be easy, cut to shape and attach. Probably just drill some small holes and use stainless screws with a washer.
Not sure what material to go for. A quick look on ebay and I'm seeing listing for neoprene rubber and silicon rubber. Anyone any idea what would work best? Thanks.
I lowered the standard cover in the rear arches to bridge the gap to the rear cross member seen here:
And I made my own out of HDPE, it was 3mm left over from my wings. I slid it up behind the inner wheel arch and used the two existing screws.
Hope this helps.
Steve
Rubber can break down relatively quickly  I used some as supports for young trees and its starting to crack with age I would say your best bet would be to use a similar material to wagon wheel guards or aluminium make them bolt on as opposed to screws as they will be easier to remove in the long run you will still need to remove occasionally to wash out behind as nothing is ever totally mud proof regards Stephen
56 minutes ago, western said:
Thanks, they look ideal. But kinda "ouch!!!" pricing.
I wonder what material they use, it just says 3mm rubber.
Also, my vehicle isn't exactly a Defender either, it's a little more bespoke. So these sadly would be unlikely to be direct fits. But the principle and material are exactly the sort of thing I had in mind.
Edited by Chicken Drumstick
They are a nylon sheet type material, definitely not rubber or silicone materials,  as for the pricing the materials, research, cutting machines all have to be recouped somehow.
  • Like 1
I would try mudguards from a HGV spares supplier. Lotsa different sizes and not expensive I wouldn't think.
HDPE is the material of choice I would say. Virtually indestructible.
Or...…..What about those 200litre or bigger blue plastic oil/chemical/water drums ? They are HDPE and you could cut and unroll them ? Might be difficult to manage though.
I have seen them in black too. Cheap and nearly, or actually free .
Polypropylene (PP) is not great, as it doesn't age well, and cracks when its cold. Plastic builders buckets and washing up bowls used to  made from HDPE and MDPE, and used to last for years. Modern ones are PP and don't last at all :(
  • Like 1
There’s a thread def2.net about this, someone has made some up recently, can’t find it at the moment though.
personally I’d go with truck wheel arches as has been said, but I like the barrel idea as I have one sat in the field!
I used my old mudflaps, from the rear.  It was time for replacements, so I cut them down and used20200405_083452.thumb.jpg.2b876ed42ec86324bac0926ab35d0344.jpg the existing bolts.
Still looking to do the rears.  Will probably use the HDPE suggestion.
  • Like 1
Hi.
I have used a tube from a traktor rear tire fixed by a couple og self tapping screws. The tube has some curve and is easy to adjust. Mine goes all the way to the mudflap, so no need for hosing down at all @FridgeFreezer (not even on my challenge truck which do see Everything...)
/Mads
Previous owner of my 110 had just got some thing sheets of Ali and riveted them in place behind the wheels on both axles.
Works well at blocking off mud. Flared the bottom a little bit so prevents stuff being kicked up into the rear cross-member. There's still plenty of space behind them to get in with a pressure washer etc. I've got a P38 air tank tucked up behind the passenger rear side.
Ohh a very long time since I did both the front and back.As my memory now goes back very little I'll see what I remember. I used olde plastic drums. I made a template to fit the back of the front wheel arch, One piece of plastin screwed by the original holes to the back of the arch. The mudflaf brackets binned then the plastic lenghtened to replace the mud flap. A new mudflap bracket made
The rear As I have side lockers in my  300Tdi I only needed to make aome aluminium bits to fill the space below the lockers, then plastic sheet from drums to make the mud flaps.
The front of the rear arches. As you know on the station wagon there is a cross member in front of the rear wheel. The crossmember gets covered in mud and crud which helps rot the cross member,So drill out the pop rivits and fit a piece of plastic to cover the crossmember. The plastic can be screwed in place
If you can understand this ?????
  • 2 weeks later...
Thought I'd update with progress.
I've used some trailer mud flaps. Quite easy to install and I like that they are flexible, so easy to hold up to wash behind, should mud still ingress. I'm going to do the same to protect the rear cross member and the outrigger in front of the rear arch. I'm also going to get some HDPE (5 litre jerry cans are cheap on ebay). To cover over the other gaps.
Front arch:
