Anderzander Posted February 7 Share Posted February 7 I saw someone on YouTube fitting one to a 300tdi, and they removed a bolt for better access and use a torx Allen key to get them out. When I’ve had limited space I’ve used the kind of Torx bit that fits in a ratchet - but put a ratchet spanner on it. It’s a bit fiddly, but fits in a tight space and gives good leverage. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 7 Author Share Posted February 7 Yes the removing that bolt on the mounting bracket would certainly help. I have a T30 for a 1/4" ratchet but it won't go in. I will need to get a t30 bent allen key. I think that I will keep the FIP as it is for now, get the engine running again and assume that I can remove the bolts and fit the spacer later, 'in-situ'. By then I may have fitted an EGT gauge which will be interesting but only if I know the 'before' temperatures too. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 7 Share Posted February 7 Have you got some Torx screwdriver bits? These are handy for this sort of tight spot: Sealey Ak6962 Bit Driver Ratchet Micro 1/4 Hex Stainless Steel : Amazon.co.uk: DIY & Tools 1 Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 7 Author Share Posted February 7 Ah that's nice and was a surprise when I clicked! I haven't seen one of those before. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 7 Share Posted February 7 Yeah, pretty good value too. Halfords include in some of their kits a 10mm hex bit holder you then use with your 10mm ratcheting spanner, which is even slimmer, but this was an easier/quicker find. 1 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted February 7 Share Posted February 7 T27 you want, same as the low fueling screw on top of the boost diaphragm. 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 8 Share Posted February 8 I used a dynamic timing advance ring on my 200. It was excellent, smoothing out engine vibration at high revs on the motorway. I'd absolutely recommend 👍 @92a had my injection pump after I stripped the 200 and he seemed very happy with it ! Mo 3 Quote Link to comment Share on other sites More sharing options...
92a Posted February 8 Share Posted February 8 Yep , still happy with it, just bought one of Vulcan Bomber’s ones for my other 200tdi powered Land Rovers 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 8 Share Posted February 8 Ps don't buy the fuelling pins off a well known ebayer, they're carp! Not hardened and you can get better fuelling with the original Land Rover pin. Mo 3 Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 8 Author Share Posted February 8 5 hours ago, Mo Murphy said: don't buy the fuelling pins off a well known ebayer, they're carp! Not hardened I have no experience of their offering and don't doubt your knowledge but I am rather gobsmacked to hear this. How can it be that they sell this quality of pin, yet appear to know what they are doing and remain in business and I think, are a popular supplier? Is it like the widely known distributor of almost everything, perhaps relying on volume and insufficient feedback / returns of shoddy goods? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 8 Share Posted February 8 1 hour ago, Peaklander said: I have no experience of their offering and don't doubt your knowledge but I am rather gobsmacked to hear this. How can it be that they sell this quality of pin, yet appear to know what they are doing and remain in business and I think, are a popular supplier? Is it like the widely known distributor of almost everything, perhaps relying on volume and insufficient feedback / returns of shoddy goods? Sadly I suspect people either don’t know there’s an issue… and then there’s also so many people these days selling all sorts that they just don’t understand in the slightest. That’s across all sorts of types of business’ too. 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 9 Share Posted February 9 8 hours ago, landroversforever said: Sadly I suspect people either don’t know there’s an issue… and then there’s also so many people these days selling all sorts that they just don’t understand in the slightest. That’s across all sorts of types of business’ too. I’m thinking Britpart. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 9 Share Posted February 9 4 hours ago, Snagger said: I’m thinking Britpart. I do think there's a difference between simply not understanding what does what, and those who are just making things down to a price without a care for quality. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 9 Share Posted February 9 Unfortunately someone let the accountants loose years ago. Which means every company must make as much profit as possible, instead of doing a good job and just making a living. Thus everything is made down to a price and this is what we all expect whether we agree/like it or not. Mike 1 Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 20 Share Posted February 20 On 2/7/2024 at 11:18 AM, Bowie69 said: Have you got some Torx screwdriver bits? These are handy for this sort of tight spot: Sealey Ak6962 Bit Driver Ratchet Micro 1/4 Hex Stainless Steel : Amazon.co.uk: DIY & Tools I have a slight addiction to 1/4 drive stuff, the dinky Sealey ratchets (also sold under many different badge engineered brands) are very useful, but can be a pain as the reverse lever thingy catches and causes absolute havoc, also bloody difficult to find after temper gets involved and tool flinging occurs. Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted February 26 Share Posted February 26 On 2/5/2024 at 1:31 PM, Nonimouse said: I've still got to finalise the purchase of the new motor. It's a 1989 LWB 461 G wagen, which is the 4x4 I've always wanted. It's solid and the only change is the engine. The 605 is a brilliant engine, almost as good as the 617. This one runs a standard mechanical pump and no intercooler, both things that will need to be addressed, although the latter is going to be fun, as there is air con fitted. Worst case scenario, I have a 617 that needs a home. Sadly this has fallen through. The lady that drives the vehicle has told her husband it's not for sale. I'm backing away slowly and carefully. He's hiding in his workshop 2 4 Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 26 Share Posted February 26 Pity for you, but maybe a harder situation for him! 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 26 Share Posted February 26 Big birthday with a 605 for the disco instead? 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 27 Share Posted February 27 On 2/7/2024 at 11:18 AM, Bowie69 said: Have you got some Torx screwdriver bits? These are handy for this sort of tight spot: Sealey Ak6962 Bit Driver Ratchet Micro 1/4 Hex Stainless Steel : Amazon.co.uk: DIY & Tools Just bought one ! 2 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 27 Share Posted February 27 Need some merch for scale. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 27 Share Posted February 27 It’s diddy! 2 1 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted February 27 Share Posted February 27 19 hours ago, landroversforever said: Big birthday with a 605 for the disco instead? It's a serious option. A 605 with a mechanical pump from a 602/662 would be about 140-150bhp if I avoided boring it out to 6mm. Smooth and nice to drive, not excessively torquey On the negative side, it won't run on Rape oil and it won't be as economic as the 200. But these are things I can put up with 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 27 Share Posted February 27 2 hours ago, Anderzander said: Just bought one ! I keep meaning to! Quote Link to comment Share on other sites More sharing options...
Stinkfloyd Posted February 27 Share Posted February 27 On 2/3/2024 at 2:14 PM, vulcan bomber said: There getting the name boost ring because there sold with them silly boost pins that I personally would avoid like the plague. Hi Vulcan bomber, Out of curiosity, are you saying to avoid all the modified boost pins? (Even the ones with a good rep?) If so, why? I'd have thought they'd work well with your timing advance kit? Is there a specific issue they cause? Cheers Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted February 27 Share Posted February 27 5 minutes ago, Stinkfloyd said: Hi Vulcan bomber, Out of curiosity, are you saying to avoid all the modified boost pins? (Even the ones with a good rep?) If so, why? I'd have thought they'd work well with your timing advance kit? Is there a specific issue they cause? Cheers In the past lots were made from soft cheap metal and would wear a groove in, messing with the fuelling and making them worse than not tampering at all. Also, you should be able to see the gains just by using the stock pin and changing its position, but you need to spend time setting it up. The modified one is just more of a generic setting. So yes, they can work. But could come with longer term risk of performance dropping off. And ultimately are a bit like applying a generic map to an ECU controlled engine. Meaning with a little more effort you can probably get better results not using one. All IMO and others may have different views. 3 Quote Link to comment Share on other sites More sharing options...
