Tarmac cleaner
Lewis
Due to my Series IIa's rather unique total loss lubrication system it has made a small enormous mess on the drive outside my mums house. Doesnt bother me :rolleyes: , but the neighbours have started to complain, and as they take in a lot of my parcels I need to keep them sweet
So, can anyone recommend a good cleaner for tarmac that will remove oil stains? I have tried the one from ScrewFix but that made the tarmac go all melty and now it looks even worse :angry: . Also I dont have access to a hosepipe or outside tap so a steam cleaner/jet washer is out of the question
Thanks
Lewis :)
The problem is that tarmac/bitumen is very much like thick oil so anything that disolves one disolves the other too. Anything I know that cleans oil off disolves tarmac .
Best solution is traffic film remover used with a pressure washer. As mark says, bitumen is just a heavier fraction of crude oil (longer hydrocarbon chains) and will start to dissolve if any of the cleaner is left on it. That's why traffic film remover works well as its only there for a short time before the water dissplaces it. My advice, bring over a pressure washer and use a tap adaptor in the house to give you a water supply. It shouldn't take long to clean the area.
Get some of the proper granules used in garages for soaking up oil.
Then spread on area when DRY and walk in "Scrunching" it with boots on, and leave for 15 mins, then apply more and again "scrunch" it around, then get a stiff brush (NOT a wire brush) and brush away, if you can leave whats left it can often "Pull" the oil out, repeat a couple of times then cover with carpet shampoo work in with some water than hose / gentle pressure wash off.
Nige
Petrol
gets it most oil stains off Concrete and then wait for the petrol to evaporate.
don't put deisel near it or the tarmac will fall apart, Gas oil is used for the cleaning of the plant etc. it will destroy tarmac in no time at all.
One of my ladswas selling his house and gave up cleaning stans from his work van off the drive but gave up and black jacked the whole drive which made the tarmac look new for about a month but it got rid of the stains.
If all that fails - chip off a bit of the tarmac and take it to Halfords.
Buy several cans of the same colour spray paint. spray area with stains. Blend in around edges - and hay presto - stains gone!
I had this with a rented house in London. The landlord didn't want to give me my deposit back because of a bit of a slik on the brand new concrete drive. An hour or so later it was gone!
10 years later, I drove past and although you could see it, it was only because the rest of the drive had changed colour!
Also used to good effect after re-spraying a door in the back yard of a different house. there was a nice green door outline on the concrete. Blended it in so it looked like a patch of green algae! Landlord was most confused when his pressure washer just made it stand out more!
Si
Thanks for your suggestions, the mess has had a few 18 months to soak in so i'm not sure sawdust will be moving it, I'll give some of the others a try after the snow has cleared
Chris, you have PM
Cheers :)
I neighbour up the road had a similar problem and was selling the place. Then one night a 'bloke in the pub' who drove a tarmac (small t) wagon said he would drop some off on Saturday for a tenner. The deal was done and the neighbour woke up on Saturday to find a whole wagon-load of steaming tarmac on the road outside his house. The rest of the day was spent 'doing' just about every drive on the street in an effort to get rid of the stuff!
Rog
Mike is right - little bit of fairy liquid in a washing up bowl with warm water and the drive looks like new. Get a scrubing brush on it, then another bowl of fresh water to rinse it away. :)
Washing up liquid well brushed in will also remove oil stains from a driveway.
mike FOAK
Knickers
I can cause trouble in an empty house !!!
First clear any excess oil. Cat litter is ok but cement powder absorbs it best.
Now clean it with a strong detergent (fairy liquid/swarfega etc), working it in with a stiff brush.
Then plenty of water and more scrubbing.
There will still be a mark left but it will gradually disappear.
Of the things I've tried (needs doing again - didn't move the rangie for a few months so there's a nice big oil patch where it was :( ), washing up liquid has been the most successful by far. Tried Gunk drive cleaner (supposed to be okay on tarmac if diluted - which is true, but it also doesn't clean the oil off...), degreaser on bad bits (cleans the oil, but also softens the tarmac). I guess even washing up liquid will be stripping the bitumen out of the tarmac, but it's been okay so far.
Pressure washer definitely helps though - I do what Will suggested and use a tap adapter.
Petrol
Petrol Petrol. :blink:
There is still a hole in the tarmac from your old Range Rover out side mums old house (the size of a large piza) , where it had a leak in the tank for ages. You Used to just park the car on top of it to hind it and that made it worse :) And you had that truck when you were 16 - 17 and you are now nearly 30 :o:o:ph34r:
Ok wait for the Ruff arse.
I had this problem . could not get rid of the stain so after a bit of thought i came up with the best solution , and that was to cover the whole area with oil and sweep it around and let soak in . This then made it look the same and therefore like it was mean't to be that colour and not a stain. Worked , never had a problem with a stain
brilliant thats even better than just leaving mud over it!
