JJ7893 Posted March 15, 2009 Share Posted March 15, 2009 Mine is zero ... Why I hear you ask. It because I dont have a defender Quote Link to comment Share on other sites More sharing options...
jason110 Posted March 15, 2009 Share Posted March 15, 2009 at 70'ish with the overdrive disengaged [out]rpm is around 3000 with overdrive engaged [in] about 2500, IIRC. my overdrive drops the revs by 500 to 600 for any speed when engaged.for example --- at 60 overdrive out rpm 2500 at 60 overdrive in rpm 2000/2100 thanks for that ralph Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted March 15, 2009 Share Posted March 15, 2009 From memory, I'm sure I used to be able to cruise at an indicated 80 - 85 without trouble which corrected would have been slightly higher. Can't remember where he used to run out of steam wasn't much more. Quote Link to comment Share on other sites More sharing options...
markyboy Posted March 15, 2009 Share Posted March 15, 2009 Well it depends how many satellite fixes you have some times you can get wildly varying results of location and speed if you only have connection to satellites over head rather than from the horizon as well that is why some units running OS based maps need about 6 fixes for true 1meter accuracy.If you use TOMTOM I don’t think there is any measure of accuracy to compare but with the more anorak (I own one so I can say that!) orientated gps units it gives you the current accuracy of location this must be the same for speed over land as that is how the gps works (I think) timed position and timed movement calculated form the atomic clocks onboard the satellite and compared to the signals from your handset . Cheers James Thanks James, Mines a Tom Tom too. Location accuracy always seems pretty good and I normally notice the maximum number of satellite connections, or at least 5 anyway. Interesting info. Mark. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted March 15, 2009 Author Share Posted March 15, 2009 Any idea what needs adjusting ? When the pedal hits the stop on the bulkhead, the throttle spindle is up against the stop on the pump. The diaphram and star wheel have already been turned 90 degrees. Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2009 Share Posted March 15, 2009 maybe the stop on the pump is not correct. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 15, 2009 Share Posted March 15, 2009 Jules had a 4.2 90 on 35" simex extreme treckers. I was following him in a Pug 406 and i lost him at 120mph . That was the max of the pug and he kept going into the distance . That was on the M3 between winchester and southampton . So never did know what he got up to in the end . Plus a bit difficult to him in the distance becasue of the rain 120+ on simex !! Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 15, 2009 Share Posted March 15, 2009 If it's any consolation, my 90 tops out at 75 ish with 255/85R16 MTs and a completely standard 120k Mile old 200tdi. I'm not sure i'd want it to go any faster, motorway crusing at the speed costs significantly more than a more comfortable 63ish mph. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted March 15, 2009 Author Share Posted March 15, 2009 maybe the stop on the pump is not correct. Are there any set figures in the green bible for how long the stop screw whould be sticking out ? Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2009 Share Posted March 15, 2009 I'll have a look. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted March 15, 2009 Share Posted March 15, 2009 My 200tdi does about 0 -0 in 3 months as its on stands Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2009 Share Posted March 15, 2009 Are there any set figures in the green bible for how long the stop screw whould be sticking out ? nothing in my defender workshop manual, the injection pump/engine Flight [no load] speed should be 3850rpm for a 200Tdi, maybe your max rpm screw needs a tweak to give a bit more rpm. Quote Link to comment Share on other sites More sharing options...
Keith Keir Posted March 15, 2009 Share Posted March 15, 2009 I seem to be getting a max speed of 75mph in my Td5 and thats downhill! But i understand that there might be a limiter on the td5 ? is this true ? Also i seem to only get about 30 mph in 3rd gear before it starts to kangaroo any ideas if thats normal or if theres something wrong ? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 15, 2009 Share Posted March 15, 2009 200 Tdi 90 on 37" Boggers Steve, What software is that ? Mo Quote Link to comment Share on other sites More sharing options...
simonb Posted March 15, 2009 Share Posted March 15, 2009 I seem to be getting a max speed of 75mph in my Td5 and thats downhill! But i understand that there might be a limiter on the td5 ? is this true ? Also i seem to only get about 30 mph in 3rd gear before it starts to kangaroo any ideas if thats normal or if theres something wrong ? Years ago I got 104.3mph GPS measured out of a TD5 110, although it was down hill and late at night on deserted dual carriageway... Quote Link to comment Share on other sites More sharing options...
reads90 Posted March 15, 2009 Share Posted March 15, 2009 120+ on simex !! Yeah i know Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted March 15, 2009 Share Posted March 15, 2009 Steve,What software is that ? Mo Hi Mo. Its the Garmin software thats used on the chart plotters. Its a GPSMAP3006 I think! Steve. P.S. Just checked, Its one of these. http://www.devon4x4.com/products_a/p1569c2...smap-3006c.html Quote Link to comment Share on other sites More sharing options...
flatback90 Posted March 15, 2009 Share Posted March 15, 2009 144kmh on the flat with 255/85 muds 1.2 bar boost in top and the pump tweaked checked with a gps. seem to remember it used to do about 75mph when standard Quote Link to comment Share on other sites More sharing options...
ian_s Posted March 16, 2009 Share Posted March 16, 2009 Are there any set figures in the green bible for how long the stop screw whould be sticking out ? i'd be checking how much turbo boost you are getting, and checking the integrity of all the high pressure air hoses, like the small one that goes over to the fuel pump. if that is blocked, you wont be getting any extra fuel into the engine. also worth flushing out your intercooler and drying it thoroughly. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted March 17, 2009 Share Posted March 17, 2009 my 90 does about 90mph pedal on the bulkhead. not particularly nice either. 70 seems just right on 235 85 Quote Link to comment Share on other sites More sharing options...
Eightpot Posted March 17, 2009 Share Posted March 17, 2009 I got a GPS 92 out of my soft top 90 when I tried a few months ago. I was feeling quite pleased with myself as well, overtaking BMW's in the outside lane, giving it large past landcruisers etc when BANG and there was a massive bright flash and a huge wall of air hit me - I thought I'd been blown up or hit by a plane - after about five seconds of intense shock and trying to get my bearings and bringing what felt like a crashing B52 bomber into the inside lane, I realised that the hood had blown off due to the force of the air! Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted March 17, 2009 Share Posted March 17, 2009 I got a GPS 92 out of my soft top 90 when I tried a few months ago. I was feeling quite pleased with myself as well, overtaking BMW's in the outside lane, giving it large past landcruisers etc when BANG and there was a massive bright flash and a huge wall of air hit me - I thought I'd been blown up or hit by a plane - after about five seconds of intense shock and trying to get my bearings and bringing what felt like a crashing B52 bomber into the inside lane, I realised that the hood had blown off due to the force of the air! that'll teach you for giving it large!!! (things always gone wrong when I'm at my cockiest! ) Forgot to add earlier, my engine is standard, rebuilt by me with the timing set around 2degrees more advanced than factory standard. My old Mum's 110 (70k since new and quiet as a whistle) will achieve around 85mph. Quote Link to comment Share on other sites More sharing options...
bluespanner Posted March 17, 2009 Share Posted March 17, 2009 Yeah i know Suprised there wasnt side lugs flying off in all directions. My truck (200tdi, 1.2 R380, 265/7516 ATs) will do about 85 but I think its overgeared, so i lose out. Roly Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 18, 2009 Share Posted March 18, 2009 Hi Mo.Its the Garmin software thats used on the chart plotters. Its a GPSMAP3006 I think! Steve. P.S. Just checked, Its one of these. http://www.devon4x4.com/products_a/p1569c2...smap-3006c.html Thanks for that Steve Ye Gods, those are expensive !!!!!! Mo Quote Link to comment Share on other sites More sharing options...
landrover598 Posted March 25, 2009 Author Share Posted March 25, 2009 Are there any set figures in the green bible for how long the stop screw whould be sticking out ? Anyone care to measure theirs for me mine is set at 12mm Quote Link to comment Share on other sites More sharing options...
