nidge Posted December 19, 2012 Share Posted December 19, 2012 My Defender 200tdi has developed want sounds like "Birds Chripping " noise when under load. Sounds nasty so can't be good. Only there when I press the trottle, when I lift off, it disappears, and also when I press the clutch its gone too ! Engine revs fine when in neutral and no drive. Checked diff, Ujs , transfer box bearing all seam fine ..So I suspect engine related or maybe gearbox. Your help or ideas, much apperciated Tks Nigel Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 19, 2012 Share Posted December 19, 2012 hmmm I think mine does that, I put it down to one of the belts... another common chirp is alternator bearings. Quote Link to comment Share on other sites More sharing options...
simonr Posted December 19, 2012 Share Posted December 19, 2012 The only thing I can think of that fits the symptoms is gearbox bearings. If you put the box in gear and the transfer in neutral, do you still get the noise? Does it make any difference how much load the transmission is under? If you jack up a wheel so it can spin freely, does it still happen? Si Quote Link to comment Share on other sites More sharing options...
moose Posted December 19, 2012 Share Posted December 19, 2012 Do the prop shaft UJ's have grease in them.... how did you check them? Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted December 19, 2012 Share Posted December 19, 2012 Sounds very much like UJ's... Pull the props off and check properly... You could probably confirm by greasing them properly, but if chirping now and it goes when grease added you are on a clock.. They are already wearing. If the grease proves the point, change them. Neil Quote Link to comment Share on other sites More sharing options...
cackshifter Posted December 19, 2012 Share Posted December 19, 2012 Sounds very much like UJ's... Pull the props off and check properly... You could probably confirm by greasing them properly, but if chirping now and it goes when grease added you are on a clock.. They are already wearing. If the grease proves the point, change them. Neil I'd second that; bird noises=u/j fubared Quote Link to comment Share on other sites More sharing options...
nidge Posted December 19, 2012 Author Share Posted December 19, 2012 Not the UJs , as I have already replaced the prop, N. Quote Link to comment Share on other sites More sharing options...
nidge Posted December 19, 2012 Author Share Posted December 19, 2012 The only thing I can think of that fits the symptoms is gearbox bearings. If you put the box in gear and the transfer in neutral, do you still get the noise? Does it make any difference how much load the transmission is under? If you jack up a wheel so it can spin freely, does it still happen? Si You might be onto something there Simon, will check your suggestion this evening. Tks N. Quote Link to comment Share on other sites More sharing options...
nidge Posted December 19, 2012 Author Share Posted December 19, 2012 What I cant get my head around is the noise increases with engine revs , and not with the speed your driving at, and no noise when drive disengaged !! N. Quote Link to comment Share on other sites More sharing options...
jetmorgan Posted December 19, 2012 Share Posted December 19, 2012 I have exactly the same problem and I know that is the elastic band that goes round the alternator. I know it's loose as the alternator is only held on by the bolt on the adjustment bracket at the moment, and as you describe when you put your foot down and the engine speeds up the noise gets worse. Also the belt as a few teeth missing so is will be replaced when I get the new alternator mounting bracket Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 19, 2012 Share Posted December 19, 2012 my monies on belts or alternator... Hmm could also be timing belt tensioner and idlers... they usually just rattle though when they're on there way out... could also be water pump bearings... but they again usually just rattle as aposed to chirp imho. Check how much end float there is on your water pump and alternator, pop the belt of the alternator and give it a spin, see if the can hear anything... spray in some WD into the alternator see if the noise goes away... also buy some anti slip belt spray, see if that makes it go away for a bit... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 19, 2012 Share Posted December 19, 2012 Honey works as a belt-grip replacement, for a while at least Quote Link to comment Share on other sites More sharing options...
Smego Posted December 19, 2012 Share Posted December 19, 2012 your all wrong it's a well known issue with Army transit vans to; Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted December 19, 2012 Share Posted December 19, 2012 try turning the belt round Quote Link to comment Share on other sites More sharing options...
Lorrick Posted December 20, 2012 Share Posted December 20, 2012 Exhaust Manifold leak ? Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted December 20, 2012 Share Posted December 20, 2012 My 200tdi does this and its the belts it seems to do it in humid or misty weather . I think I need to tension the belts a bit more. Quote Link to comment Share on other sites More sharing options...
crclifford Posted December 20, 2012 Share Posted December 20, 2012 your all wrong it's a well known issue with Army transit vans to; If you ask my Royal Marine mate, it also happens in their vehicles too!!!! (Can you tell that I'm a Sapper!) Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 20, 2012 Share Posted December 20, 2012 I'd put money on the alternator belt. Mine chirps when its cold or damp. Have you got a rev counter? That will show if the alternator is slipping Quote Link to comment Share on other sites More sharing options...
nidge Posted December 21, 2012 Author Share Posted December 21, 2012 Had a quick look at the alternator last night in the dark... the pulley looks in poor condition, rung the the head on the 10mm bolt trying to get the alternator off !! Will tackle it at the weekend but could be the source of the problem , will update in due course. Many tks to all for help, a top forum when you need a problem sorted ! Nidge. Quote Link to comment Share on other sites More sharing options...
nidge Posted December 27, 2012 Author Share Posted December 27, 2012 Problem sorted hopefully..changed alternator and belt and the chirping has gone !! Or the birds fell out of their nest Smego Tks Again Nidge. Quote Link to comment Share on other sites More sharing options...
mhemingway Posted April 28, 2018 Share Posted April 28, 2018 @nidge was the problem the alternator belt? I have a 200tdi and I am experiencing a similar issue. Quote Link to comment Share on other sites More sharing options...
western Posted April 28, 2018 Share Posted April 28, 2018 possibly alternator bearings Quote Link to comment Share on other sites More sharing options...
