Lionhound
Advice on fitting Mazda RX8 seats.
Ok so looking for a bit of comfort as in everyday use for work. Been given a pair of seats from an rx8 (heated and electric on drivers)
Anyone put these in? Anyone able to advise on how?
Not bothered about electrics for now (plenty probs with them already!!!) Though would be interested to hear if theres a quick way just to alter rake and position for now (rest can wait)
Thanks people.
Rab
  • Like 4
Share this post
Link to post
ill be doing this shortly, so would be interested in any information or if none is available then watch this space and ill come up with a solution
thanks
tom
Share this post
Link to post
I've fitted Mazda seats to my Defender - brilliant pieces of kit and the electrics are easy to do. You also need to remember that seat adjustment is now part of the MOT so you may as well sort that too.
I chopped the mounting rails and welded so they mounted on a flat surface, then I think I picked up on the original mounting holes on one side. However r! I had not noticed that the latches for the doors were going to foul on the door cards (Homer Simpson moment). I only found out when I tried to close the door and ended up hacking the plastic housings on the seats....
Share this post
Link to post
Nice seats, aren't they a bit high, I know that Defenders have the higher windscreen than Series.
I have Old Datson 120 seats on my LR which are comfy and look OK but I have to peer out under the top as they are a bit high.
I now have a set of Ford Recaro seats to go in.
Share this post
Link to post
i Picked up the seats today, look great.
ill be fitting them tomorrow but in my opinion theres no welding necessary, just cut off the original brackets and bolt done thru the rails into the seat box.
NOTE:
ENSURE YOU REMOVE ANY AIRBAGS !!!!CAREFULLY!!!!
TRY NOT TO DRILL INTO YOUR FUEL TANK
Share this post
Link to post
I personally would weld brackets on to mount on original holes as that is where the seat box is degined to take loading and forces excerted by a seat
Share this post
Link to post
NOTE:
Very intrerestuing threwad / upgarde - watching to see whow these are fitted wired etc but puzzled re : Air Bags ?????
Share this post
Link to post
Some seats have air bags in the sides for side impacts and to deflect the window glass I think. A Google search for seat airbags shows the pictures.
Share this post
Link to post
wowzer, .........
..........a description of where they are on RX8s and how to get at them / remove would be interesting / useful ?
Share this post
Link to post
Ok, A little More on fitting, sorry no pics ill get some tonight.
AirBags- these are the side airbags and can be carefully removed my flipping up the SRS logo undoing a bolt and then the whole air bag can be lifted off (personally I dislike having them there at all so I then undid the 3 nuts holding the airbag to the metal plate, prized off the plastic cover, unfolded and cut open the bag and removed the airbag 'firing unit' then refitted the plate and plastic cover to the seats (Note: air bags can be very dangerous so anything you do to them is at your own risk and whatever you do - DO NOT let any electricity near to the units!!
Next I cut off all the brackets under the seat rails, easy job, then line the seats up where you want them and bolt the rails straight to the seat box at the front, I found the original holes are slightly off, so I drilled new holes and fitted rivnuts, I then fitted approx. 6mm spacer under the rails so the drivers seat motors don't foul the seat box.
next step, test and check you are happy with the seats, all inline and don't foul when moved about Awesome
Electrics on the seats:
Yellow Plug - SRS, bin this
Seat Motion - Thick Grey +12V
Thick Purple Ground
Lumber - Yellow Red Trace +12V
White Yellow Trace Ground
Seat Heater - Blue +12V
I haven't bolted the rear of the seats down yet but I will probably make a mount so that the seats are lifted a bit at the rear so the seat base clears the seat box covers,
Share this post
Link to post
A couple of months ago, I was looking for the wiring diagram for RRS heated seat controllers - and found a Ford Forum where a member had posted a photo of the underside of his drivers seat asking if the plug shown could be for heated seats? The plug was yellow!
Surprisingly, nobody in the subsequent posts suggested this might be the Airbag. Eventually after some speculation someone suggested putting power in to it to see if the seat heats up. (I'm thinking Nooooo!)
A couple of posts further on - there was a photo of the seat split open where the airbag had exploded out of the side. ;)
Guess it did heat up, albeit rather briefly!
Top Tip - Avoid any yellow wiring!
Si
Share this post
Link to post
Did I read that right, you've used rivnuts to secure the seats to the vehicle?
My standard defender seats are bolted down into rivnuts, albeit 1 tonne rivnuts. All TD5 defenders use rivnuts from factory
Share this post
Link to post
Yep Rivnuts, that's what the more modern defenders have OEM,
haha Si that would be interesting to see (note: never energize something you are unsure of
Share this post
Link to post
Aibags can be fun (with the standard dont try this at home warning). The ones i removed from my Audi A6 seats and the Merc i stripped for the motor got put to good use.
I was able to get the merc steering wheel a good 30ft into the air, at the end of a long cable and fired by a 12v battery.
Share this post
Link to post
You are having a laugh.
If the seatbelt mount is to the seat thats downright stupid. Even if its to the body, thats a huge weight which is going to rip out in a crash and try to meet the nut behind the wheel.
Share this post
Link to post
BAd as that might be, if you are worried about that in a crash, you shouldn't really be driving a Land Rover ;):)
Share this post
Link to post
Have you ever seen a Defender? The seats and seatbelt mounts are different.
Share this post
Link to post
RX8 seats have the belt clip on the seat, so if you use that... then well :)
Share this post
Link to post
Yes, i've owned 3. Your point is? One should do something dangerous just because its a Defender?
If you mean that the belt mounts are direct to correct points, then thats one step better (if he hasn't used the seat mounts for the belts). But I would not want be sitting on 50kg of unrestrained mass in an accident.
Recommending Rivnuts into 1.5mm aluminium for seat mounts in a write-up is not something that should be published on a responsible forum.
It's not exactly difficult to use some decent spreader washers.
Share this post
Link to post
