SteveG Posted September 4, 2016 Share Posted September 4, 2016 I think I heard/read somewhere that it's not advisable to paint propshafts, due to risk of putting them out of balance. Is this correct, or just urban myth? Can a coat of paint really cause that much of an issue? Expert advice wanted please, and if correct, how do you get them refurbished? Cheers Steve Quote Link to comment Share on other sites More sharing options...
Davo Posted September 4, 2016 Share Posted September 4, 2016 Just a coat of spray paint isn't going to hurt anything, and it's what reconditioners do anyway. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 4, 2016 Share Posted September 4, 2016 Maybe on an F1 car but I don't think I'd worry about anything Land Rover make as long as you're not painting it with brush on bitumen. The actual weight of paint in a small spray can is pretty insignificant and if you apply it reasonably evenly, the weight imbalance is going to be minimal. Quote Link to comment Share on other sites More sharing options...
mad_pete Posted September 4, 2016 Share Posted September 4, 2016 I'm going to go with Myth busted. 1 Quote Link to comment Share on other sites More sharing options...
missingsid Posted September 4, 2016 Share Posted September 4, 2016 Neither my wheels nor my diy shortened propshaft have been balanced and there are no ill affects! Quote Link to comment Share on other sites More sharing options...
Lewis Posted September 4, 2016 Share Posted September 4, 2016 I paint both props every time I put another coat on the chassis, and I just slap floor paint on with a brush, I shouldn't worry Quote Link to comment Share on other sites More sharing options...
SteveG Posted September 4, 2016 Author Share Posted September 4, 2016 Thanks everyone, as I thought - and rear prop now painted! Quote Link to comment Share on other sites More sharing options...
Jon White Posted September 4, 2016 Share Posted September 4, 2016 Neither my wheels nor my diy shortened propshaft have been balanced and there are no ill affects! Ditto. Never balanced a prop, nor any of the wheels on my truck. Quote Link to comment Share on other sites More sharing options...
robertspark Posted September 5, 2016 Share Posted September 5, 2016 Balanced the wolf rims on mine just the once... there was a bit of complaint over the amount of lead used by the tyre fitters.... drove out and could see the weights flying off in the mirror... Quote Link to comment Share on other sites More sharing options...
Popular Post landrover598 Posted September 5, 2016 Popular Post Share Posted September 5, 2016 Make sure you use anticlockwise paint otherwise you'll end up with transmission wind up. 7 Quote Link to comment Share on other sites More sharing options...
SteveG Posted September 6, 2016 Author Share Posted September 6, 2016 Make sure you use anticlockwise paint otherwise you'll end up with transmission wind up. Does this mean that our friends south of the equator, have to use clockwise paint??? 1 Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 6, 2016 Share Posted September 6, 2016 Does this mean that our friends south of the equator, have to use clockwise paint??? Yes. You should see the mess it makes of the halfshafts if you use the wrong stuff. You could use them for corkscrews 2 Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 6, 2016 Share Posted September 6, 2016 What happens when passing the Equator going South ? Will this upset the paint... Quote Link to comment Share on other sites More sharing options...
Peaklander Posted September 6, 2016 Share Posted September 6, 2016 Coast over in neutral. That should be safe enough. Quote Link to comment Share on other sites More sharing options...
SteveG Posted September 6, 2016 Author Share Posted September 6, 2016 Logic would dictate that once over the equator, you only use reverse until your back. Quote Link to comment Share on other sites More sharing options...
Davo Posted September 7, 2016 Share Posted September 7, 2016 It's a real pain ordering parts from the UK because I have to specify "reverse rotational paint" and it always costs extra! Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 7, 2016 Share Posted September 7, 2016 I have a tin of it, if you'd like to buy it. £200 per litre, but shipping is costly as it has to travel via both poles to be correctly magnetised, so that's £400 per litre. But I did put "4x4" on the label, so it's worth it. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 7, 2016 Share Posted September 7, 2016 Is it orange as well, snagger? Quote Link to comment Share on other sites More sharing options...
hangover Posted September 7, 2016 Share Posted September 7, 2016 It's a real pain ordering parts from the UK because I have to specify "reverse rotational paint" and it always costs extra! Many an Aussie has been caught out like this, thats why i have a 20ltr drum of anti-clockwise paint to repaint all my spares. Quote Link to comment Share on other sites More sharing options...
hangover Posted September 7, 2016 Share Posted September 7, 2016 I have a tin of it, if you'd like to buy it. £200 per litre, but shipping is costly as it has to travel via both poles to be correctly magnetised, so that's £400 per litre. But I did put "4x4" on the label, so it's worth it. Being where you are, i think you need a tin of each . Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 7, 2016 Share Posted September 7, 2016 Is it orange as well, snagger? Oh no. I don't do orange - I had a terrible employer far too keen on the damned colour! Quote Link to comment Share on other sites More sharing options...
Peaklander Posted September 7, 2016 Share Posted September 7, 2016 It's cheap and easy though isn't it? Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 7, 2016 Share Posted September 7, 2016 Not that cheap, and easy only in name! Quote Link to comment Share on other sites More sharing options...
ballcock Posted September 7, 2016 Share Posted September 7, 2016 Can you still buy Tartan paint in Scotland? I heard the EU. had banned it because the Clans were arguing over copyright. Quote Link to comment Share on other sites More sharing options...
Davo Posted September 9, 2016 Share Posted September 9, 2016 On 9/7/2016 at 2:52 PM, Snagger said: I have a tin of it, if you'd like to buy it. £200 per litre, but shipping is costly as it has to travel via both poles to be correctly magnetised, so that's £400 per litre. But I did put "4x4" on the label, so it's worth it. Thanks, but I just ordered a paint reversal system from eBay. It runs on magnets, I believe. It should be here soon because it only has to come from Hong Kong. Quote Link to comment Share on other sites More sharing options...
