Ed Poore Posted February 2, 2023 Share Posted February 2, 2023 That looks like a 4ft version? There is a 5ft version of it. If an extra foot would work. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 2, 2023 Author Share Posted February 2, 2023 1 minute ago, Ed Poore said: That looks like a 4ft version? There is a 5ft version of it. If an extra foot would work. Trouble is tyres are still well on the ground, 5' would be better but I think limiting straps are the solution Regards Stephen Quote Link to comment Share on other sites More sharing options...
bishbosh Posted February 2, 2023 Share Posted February 2, 2023 Regarding the grippiness (or lack there of) of the rock sliders, when your boots are full of mud grip tape is going to struggle. When I built sliders for my 90 many years ago I cut thin slices (6 ish mm) of tube and welded them to the top face of the slider. Worked really well and provided plenty of bite for soles to grip. 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 2, 2023 Share Posted February 2, 2023 1 hour ago, Stellaghost said: jack is too short to lift wheels off the ground..... Welcome to the world of portals! 3 Quote Link to comment Share on other sites More sharing options...
Blanco Posted February 2, 2023 Share Posted February 2, 2023 .... or get the longer one? Quote Link to comment Share on other sites More sharing options...
elbekko Posted February 2, 2023 Share Posted February 2, 2023 1 hour ago, Ed Poore said: That looks like a 4ft version? There is a 5ft version of it. If an extra foot would work. Because what a high-lift needs it more sketchiness. 4 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 2, 2023 Author Share Posted February 2, 2023 Offside sorted Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
markyboy Posted February 2, 2023 Share Posted February 2, 2023 3 hours ago, Stellaghost said: Nearside rock slider completed Brackets drilling and tapping Sorted Regards Stephen They look great, excellent work as ever, Stephen. regards, Mark 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 2, 2023 Share Posted February 2, 2023 3 hours ago, Ed Poore said: That looks like a 4ft version? There is a 5ft version of it. If an extra foot would work. Depends if he's got 5ft of storage anywhere in the truck without it sticking out the top Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 2, 2023 Author Share Posted February 2, 2023 Just now, FridgeFreezer said: Depends if he's got 5ft of storage anywhere in the truck without it sticking out the top Won't need the 5' one I have a cunning plan.......... Regards Stephen Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted February 2, 2023 Share Posted February 2, 2023 This? 2 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 2, 2023 Share Posted February 2, 2023 Or .. 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 2, 2023 Author Share Posted February 2, 2023 16 minutes ago, Ed Poore said: This? 1 minute ago, Anderzander said: Or .. Are either of those stuck in a rut axle bound....... Thought not..............lol Regards Stephen Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted February 2, 2023 Share Posted February 2, 2023 No but I have seen one of the Nemesises (or whatever the plural is) stuck with all four wheels bogged to the top in sand. They activated the jack, lifted the vehicle out. Shovelled sand back in the holes and put a waffle board under the two rear ones and drove off. Think they'd even tied them to the back of the truck so they didn't have to stop to collect them until they were clear of the soft sand. No idea if they stayed attached with 500hp under the bonnet. 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 2, 2023 Share Posted February 2, 2023 That train is definitely in a rut ! Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 3, 2023 Author Share Posted February 3, 2023 No time today other than to finish off rock sliders to mud guard seams Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
hurbie Posted February 3, 2023 Share Posted February 3, 2023 how the hell do you get that seam so smooth 😉 (i always end up with sealant all over the place ) Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted February 3, 2023 Share Posted February 3, 2023 6 minutes ago, hurbie said: how the hell do you get that seam so smooth 😉 (i always end up with sealant all over the place ) Someone’s clearly never licked their finger while using the squirt gun😂 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted February 3, 2023 Author Popular Post Share Posted February 3, 2023 3 minutes ago, hurbie said: how the hell do you get that seam so smooth 😉 (i always end up with sealant all over the place ) I mask it off, put a bead of Sikaflex in then dip my finger in white spirit and smooth down the bead, the Sikaflex will not stick to the white spirit on your finger. A long seam may require to dip your finger a couple of times. Remove the masking tape and smooth over again as above, job done. Regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 3, 2023 Share Posted February 3, 2023 The other trick is to push the sealant gun not pull it. Once you get good at it you won't need to mask it. Mike 2 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 3, 2023 Share Posted February 3, 2023 Or spray it down with water before you smooth it. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted February 4, 2023 Share Posted February 4, 2023 The finish on those sliders is nicer than the paint on my car...... 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 4, 2023 Author Share Posted February 4, 2023 1 hour ago, ThreePointFive said: The finish on those sliders is nicer than the paint on my car...... An exaggeration but thank you Johnson's black paint brushed on Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 5, 2023 Author Share Posted February 5, 2023 Started putting some of the gearbox tunnel together First some rivinuts Paint regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 5, 2023 Author Share Posted February 5, 2023 Rest of tunnel and floor plates made and fitted, floor plates still to drill and rivnut, but other stuff to finish off before they can be fitted for good Regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
