Popular Post Stellaghost Posted July 17, 2021 Author Popular Post Share Posted July 17, 2021 Project interruption unit regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 17, 2021 Share Posted July 17, 2021 To be fair it's a tad hot for welding today..... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 17, 2021 Share Posted July 17, 2021 Stephen is in the dark north… he’ll have waist deep snow 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted July 17, 2021 Author Share Posted July 17, 2021 1 hour ago, landroversforever said: Stephen is in the dark north… he’ll have waist deep snow That's why I need a ground clearance heavyweight to bash through the snowdrifts oh and I'm not exactly tall either lol regards Stephen Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 17, 2021 Share Posted July 17, 2021 Ah...... finally it comes out, you are building a snow plough. 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted July 18, 2021 Author Share Posted July 18, 2021 Bit of a long afternoon ahead Done some more chain drilling much easier than spending forever with a cutting disc and better for following a profile the long afternoon part putting my radius construct on a diet in the mill regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Timc20xe Posted July 20, 2021 Share Posted July 20, 2021 some Great work mate . can you remember the od of the inner axle tube ? cheers Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted July 20, 2021 Author Share Posted July 20, 2021 1 hour ago, Timc20xe said: some Great work mate . can you remember the od of the inner axle tube ? cheers Thanks OD of inner axle tube is 80mm and wall thickness is 6mm regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 21, 2021 Share Posted July 21, 2021 On 7/18/2021 at 11:27 AM, Stellaghost said: If I was doing this - that would be about as good as it would ever look… …you on the other hand seem to be able to turn things out that look factory finish. I can’t wait to see how this is going to look. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted July 21, 2021 Author Share Posted July 21, 2021 41 minutes ago, Anderzander said: If I was doing this - that would be about as good as it would ever look… …you on the other hand seem to be able to turn things out that look factory finish. Looking at your 80" your doing yourself an injustice Time and patience with a little help from some gear you would be surprised what you could do regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted July 22, 2021 Author Share Posted July 22, 2021 Started on its twin need to machine shaft on and then Mill it to the same thickness after that I will machine a couple of pins to knock into holes so I can Mill them together and achieve an identical profile regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted July 26, 2021 Author Share Posted July 26, 2021 Doesn't look like a lot of progress but it's taken me ages to get to this point Second one on a diet shaft turned in lathe and then cut into two pins and radius arms pinned together then put in Mill vice and started profiling You can see its starting to take shape ( a long way to go) at least to a position where it can be finished off with flap wheels and discs going down the grades until I achieve the finish I want regards Stephen 2 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted July 26, 2021 Share Posted July 26, 2021 Great stuff Stephen , they look to be a pretty accurate pair . You must have to run to the scrap yard with swarf once a week! just out of interest , is that plate S355 or S275 ? I suspect it won't matter with the level of fabrication going on , just love it Steve 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted July 26, 2021 Author Share Posted July 26, 2021 5 minutes ago, steve b said: Great stuff Stephen , they look to be a pretty accurate pair . You must have to run to the scrap yard with swarf once a week! just out of interest , is that plate S355 or S275 ? I suspect it won't matter with the level of fabrication going on , just love it Steve Thanks Scrap man is a happy bunny with my deposits at the moment lol I would love to answer your question on the steel as there are no markings on it and sections were cut off a piece that's been laid in our works graveyard for a long time. I do know it has also been used for pressing dies in the big press at work so I would suspect it will be the S355 but the honest answer escapes me regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted July 30, 2021 Author Popular Post Share Posted July 30, 2021 Getting there regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 30, 2021 Share Posted July 30, 2021 Oh my word - you’ve done it again. That looks factory. Brilliant work. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted July 30, 2021 Author Share Posted July 30, 2021 2 minutes ago, Anderzander said: Oh my word - you’ve done it again. That looks factory. Brilliant work. Not finished yet regards Stephen Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 30, 2021 Share Posted July 30, 2021 That rusty concrete is a sure sign of all the hard work done.... and abrasives sacrificed Quote Link to comment Share on other sites More sharing options...
Arjan Posted August 1, 2021 Share Posted August 1, 2021 All I can do is watch in awe.... Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 2, 2021 Author Share Posted August 2, 2021 I've now got a happy radius arm part, just need to do the other one regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 2, 2021 Share Posted August 2, 2021 Damn! Now you are showing off 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 2, 2021 Author Share Posted August 2, 2021 3 minutes ago, CwazyWabbit said: Damn! Now you are showing off Sorrry I thought it looked a bit bland with flat sides lol regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 2, 2021 Share Posted August 2, 2021 How did you do it? Is that done by hand with a die grinder? Looks great 😀 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 2, 2021 Author Share Posted August 2, 2021 16 minutes ago, CwazyWabbit said: How did you do it? Is that done by hand with a die grinder? Looks great 😀 No, roughed it out with a disc grinder and finished with a 41/2 flap disc and some emery paper regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 2, 2021 Author Share Posted August 2, 2021 28 minutes ago, CwazyWabbit said: Damn! Now you are showing off This might be called showing off lol 3 Quote Link to comment Share on other sites More sharing options...
