landroversforever Posted September 11, 2020 Share Posted September 11, 2020 I’d have to say genuine rubber too. Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 11, 2020 Share Posted September 11, 2020 On 8/15/2020 at 5:18 PM, western said: I fitted a set of Superpro bushes on my 110 to everywhere except dampers as they are on OME polybushes any way, it drives/rides & handles very well. You won't pick up the axle on your own with a assistant or crane/trolley jacks, they are very heavy. I got a Discovery front axle and 110 Salisbury rear in and out of my Sankey alone and it was probably one of the more stupid things I’ve tried. I didn’t injure myself, but that was probably more luck than the very shaky judgement! Quote Link to comment Share on other sites More sharing options...
paime Posted September 11, 2020 Author Share Posted September 11, 2020 2 hours ago, landroversforever said: I’d have to say genuine rubber too. https://rimmerbros.com/Item--i-RA1173EARLY Something like that? A bit pricier than poly but if it lasts longer then i'm all ears. Any issues with installing? Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 11, 2020 Share Posted September 11, 2020 1 hour ago, paime said: https://rimmerbros.com/Item--i-RA1173EARLY Something like that? A bit pricier than poly but if it lasts longer then i'm all ears. Any issues with installing? That price is insane. If they weren’t so greedy, Gen Parts would sell a lot more parts and be more profitable. 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 12, 2020 Share Posted September 12, 2020 They were hugely expensive when I bought them, i had to do it an axle at a time BUT that is an obscene price ! At that price I'd reconsider the superpro which were the best of the poly bushes I tried. Mo Quote Link to comment Share on other sites More sharing options...
paime Posted September 12, 2020 Author Share Posted September 12, 2020 I'm quite tempted by Superpro mainly because they seem so much easier to fit. I don't have access to a press so I'm not sure if I could even fit rubber bushes myself. This morning I finished stripping the remaining bits from the axles and welded a bit where I had been a bit too enthusiastic with a cutting disc. I then turned my attention to getting the old bushes out of the trailing arms etc. For the panhard rod, is there a metal insert I have to remove as well or is that lip part of the casting? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 12, 2020 Share Posted September 12, 2020 The metal insert is the outer part of the bush and needs to come out. Cut through it gently with a hacksaw and then knock it inwards and out with a chisel. Personally I think genuine bushes are fairly good value considering how long they last under normal conditions. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted September 12, 2020 Share Posted September 12, 2020 (edited) oe rubber bushes are good, but a absolute PITA to remove, that's why i'm a convert. The superpro went in easy and i know if i have to change them they will come out easy enough. I think the worst set of oe bushes to remove on my 110 were the rear A frame bushes which were triple sleeved. Not to mention the mess the rubber makes of everything you use on them. Pete P.S in you picture above they all have an outer sleeve that i can remember, they either need a press to remove in one or a deft hand with a hacksaw to cut two very close parallel cuts so you can use a chisel to tear a thin strip out. If you cut too far with the hacksaw you risk knackering the arms/rods. Edited September 12, 2020 by pete3000 p.s Quote Link to comment Share on other sites More sharing options...
paime Posted September 12, 2020 Author Share Posted September 12, 2020 2 hours ago, pete3000 said: P.S in you picture above they all have an outer sleeve that i can remember, they either need a press to remove in one or a deft hand with a hacksaw to cut two very close parallel cuts so you can use a chisel to tear a thin strip out. If you cut too far with the hacksaw you risk knackering the arms/rods. This was my next question and I had visions of cutting away only to realise there was never a metal sleeve to begin with. If i go OE then I might also finally have an excuse to buy a press at long last. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 12, 2020 Share Posted September 12, 2020 24 minutes ago, paime said: I might also finally have an excuse to buy a press at long last. You will be suprised at how useful a press will be well worth having in your arsenal of tools regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 13, 2020 Share Posted September 13, 2020 You only need to do a single cut to make the bush come out.... and IMO it doesn’t even need to be all the way through. It just needs a weakness you can get the cold chisel onto. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted September 13, 2020 Share Posted September 13, 2020 I use a pointing chisel, I think they are called, used for knocking mortar out between bricks. Very strong and only about 6mm wide blade. Once you get it started it peels it back Quote Link to comment Share on other sites More sharing options...
paime Posted September 13, 2020 Author Share Posted September 13, 2020 Managed to get the bushes out of the panhard rod and trailing arms today but abandoned the radius arms. The first couple came out exactly as described but the last 2 were an absolute nightmare. First pic is the first sleeve, the second pic is the last one. It had pretty much welded itself to the surrounding metal and took a lot of bashing and swearing. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 13, 2020 Share Posted September 13, 2020 Not uncommon for when I was removing bushes before I bought a press Quote Link to comment Share on other sites More sharing options...
western Posted September 13, 2020 Share Posted September 13, 2020 I had a similar result when replacing the old genuine metalstik bushes. lots of hammer/chisel & hacksaw action. Quote Link to comment Share on other sites More sharing options...
paime Posted September 14, 2020 Author Share Posted September 14, 2020 (edited) i'm getting a little confused with my polybush purchase and can't find mid-production TD5 kits. Everything is either up to '93 or '02 to '07. Will the '02 to '07 kit fit my 1999 TD5? I'm not sure what the main changes were. Edit: Ignore that, i think the 1999 TD5's have the wider radius arms so will go for that. Edited September 14, 2020 by paime Quote Link to comment Share on other sites More sharing options...
inguz Posted September 14, 2020 Share Posted September 14, 2020 While we're on the topic can anyone recommend a good press? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 14, 2020 Share Posted September 14, 2020 For DIY, any of the offerings that all come out of the same factory in China are fine. Go with at least 20T, and as wide a bed as you can afford. Quote Link to comment Share on other sites More sharing options...
western Posted September 14, 2020 Share Posted September 14, 2020 2 hours ago, paime said: i'm getting a little confused with my polybush purchase and can't find mid-production TD5 kits. Everything is either up to '93 or '02 to '07. Will the '02 to '07 kit fit my 1999 TD5? I'm not sure what the main changes were. Edit: Ignore that, i think the 1999 TD5's have the wider radius arms so will go for that. You need the '93 to '02 set. Quote Link to comment Share on other sites More sharing options...
paime Posted September 17, 2020 Author Share Posted September 17, 2020 Some more progress: axles, radius arms, trailing arms and panhard rod are all off to get blasted and painted so I've got more room for the new chassis. 2 coats of Bilt Hambet Etchweld are on and im going to use a rattle can for the third as there are quite a few places where a brush won't reach. Epoxy mastic goes on after this then hopefully the axles will arrive back from the painters. 2 Quote Link to comment Share on other sites More sharing options...
paime Posted September 17, 2020 Author Share Posted September 17, 2020 I'm a little bit worried as there appears to be a slight twist in the chassis which you can just make out in those pics. Will it all settle into something more level when the engine is in and weight is applied? Quote Link to comment Share on other sites More sharing options...
ballcock Posted September 18, 2020 Share Posted September 18, 2020 If it's twisted I would send it back. There is a method to check if it is straight using datum points on a flat floor. Check in Rave for details. Quote Link to comment Share on other sites More sharing options...
C18RCH Posted September 19, 2020 Share Posted September 19, 2020 On 9/17/2020 at 10:43 PM, paime said: I'm a little bit worried as there appears to be a slight twist in the chassis which you can just make out in those pics. Will it all settle into something more level when the engine is in and weight is applied? As above if it is, then send it back. You’ll have no end of problems getting bodywork to line up if it’s twisted. It’s bad enough with a straight chassis. easy enough to measure. Get it supported evenly on a flat floor, then measure the corners and check that it’s all level relative to other parts if it. if you can’t get it all level, it’s twisted. Quote Link to comment Share on other sites More sharing options...
paime Posted September 19, 2020 Author Share Posted September 19, 2020 Went out this morning and measured everything I could. Its not helped by by axle stands also not being level but im seeing a difference of between 3 and 5mm across the whole thing. I think that should be fine but will I see fitment difficulties? Quote Link to comment Share on other sites More sharing options...
C18RCH Posted September 19, 2020 Share Posted September 19, 2020 2 minutes ago, paime said: but will I see fitment difficulties? Almost certainly. It’s a landy after all. however, I would say 3-5mm is within allowable tolerances. Quote Link to comment Share on other sites More sharing options...
