HoSS Posted May 26, 2020 Author Share Posted May 26, 2020 Well its been a long time with no update, put that down to time and money. However the bonus of Covid is that i got to spend 8 weeks in my garage isolating with my loved one (Truck not Mrs). I've reworked the tilting cab a little, worked on the engine clearances to the diff (still need to cut & weld the sump to improve), but mainly worked on the technical area (is what i'm calling it) Its a structure behind the cab that holds batteries, air compressor, hydraulic pump and there will be 2x 60L water tanks. I'll post some pictures soon. On other developments - I always wished i'd bought the longer 6x6 chassis, and am in discussion with a chap to buy a rolling chassis, but fret not all of my work can be trasnfered over. 3 Quote Link to comment Share on other sites More sharing options...
Santa Posted May 27, 2020 Share Posted May 27, 2020 On 5/26/2020 at 4:21 PM, HoSS said: Well its been a long time with no update, put that down to time and money. However the bonus of Covid is that i got to spend 8 weeks in my garage isolating with my loved one (Truck not Mrs). I've reworked the tilting cab a little, worked on the engine clearances to the diff (still need to cut & weld the sump to improve), but mainly worked on the technical area (is what i'm calling it) Its a structure behind the cab that holds batteries, air compressor, hydraulic pump and there will be 2x 60L water tanks. I'll post some pictures soon. On other developments - I always wished i'd bought the longer 6x6 chassis, and am in discussion with a chap to buy a rolling chassis, but fret not all of my work can be trasnfered over. Consider getting a tgb 20 chassis, that way you can get the 606 to sit behind the front diff like the B30 does. I extended my tgb13/14 chassis by 400mm for that reason, no need to cut the sump for clearance + you end up with a reasonable length rear tailshaft Quote Link to comment Share on other sites More sharing options...
HoSS Posted May 27, 2020 Author Share Posted May 27, 2020 Thing is the 6x6 chassis dont come up every day, I've not seen a 20 chassis available. And bonus with this one is it has papers already for Diesel, so less headache registering. But you have a point, maybe even on the 1314 chassis the motor can be moved back, probably requires the round crossmember to be moved. Quote Link to comment Share on other sites More sharing options...
Santa Posted May 30, 2020 Share Posted May 30, 2020 Sounds like a good option, the x member would not be too difficult to move back. Also depends if you change from an auto back to a manual you might not need to move it at all. Cheers Nick Quote Link to comment Share on other sites More sharing options...
Popular Post HoSS Posted June 7, 2020 Author Popular Post Share Posted June 7, 2020 Ok the promised updates. I've built a 'technical' box which includes the 2 batteries with main fuses & isolators on the left, and the hydraulic pump and compressor on the right. All of those slide out on drawer runners for maintenance. The 2 upper volumes are for water tanks, should be able to get at least 60L each side. The frame takes the body width out to 2m this will be able to put a bed crosswise. Its just tack welded for now, when i'm happy it will be taken down, welded & powder coated. This last one is a hydraulic lifting spare wheel carrier, since my wheels are at least 50kg. When lowered down it will also serve as steps into the rear cabin \ And the lifting cab in operation. Access to the engine before this was through a little hatch in the cab and practically impossible. Acheived by fitting hinges to the front bumper, routing all cables, tubes and brake lines suitably, a hydrailic ram and when down boltable mounts. IMG_20200607.MOV 5 1 Quote Link to comment Share on other sites More sharing options...
Arjan Posted June 8, 2020 Share Posted June 8, 2020 You have been busy ! Looks impressive. Quote Link to comment Share on other sites More sharing options...
HoSS Posted July 31, 2020 Author Share Posted July 31, 2020 So i've been lucky enough to find a TGB13 (6x6) chassis in excellent condition, these are as rare as anything these days. Along with another OM606 which has had a nice new Diesekmaken pump and an ML gearbox with a custom Tx box adaptor. All of my work on the cab and other bits will transfer across. Now for some scraping, sandblasting and chassis paint... 4 Quote Link to comment Share on other sites More sharing options...
missingsid Posted July 31, 2020 Share Posted July 31, 2020 Ooh my Green Eyed Monster has reared its head. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted July 31, 2020 Share Posted July 31, 2020 Now I'm really jealous. Well more than before. Mike Quote Link to comment Share on other sites More sharing options...
Blanco Posted July 31, 2020 Share Posted July 31, 2020 Not sure if it is just the perspective, but that chassis is making the tow car look very small! Hoss are you thinking of dumping the merc ecu? (I take it the Dieselmeken pump is entirely mechanical) or is this just going on the spares shelf? Quote Link to comment Share on other sites More sharing options...
HoSS Posted July 31, 2020 Author Share Posted July 31, 2020 2 hours ago, Blanco said: Not sure if it is just the perspective, but that chassis is making the tow car look very small! Hoss are you thinking of dumping the merc ecu? (I take it the Dieselmeken pump is entirely mechanical) or is this just going on the spares shelf? I'm a bit undecided, the ECU has its advantages, smoother, diagnostics, but the manual pump has more power (in fact i will have to detune it a bit to lose the black smoke) but has the advantage of no electronics. Dieselmaken is a swedish company that specialises in upgrading the mercedes M pumps, larger elements etc. Quote Link to comment Share on other sites More sharing options...
HoSS Posted October 2, 2020 Author Share Posted October 2, 2020 Some progress, most of the chassis stripped and painted with EM121 Epoxy. 4 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted October 2, 2020 Share Posted October 2, 2020 I have to admit I was expecting to see more crossmembers than there is. Mike 1 Quote Link to comment Share on other sites More sharing options...
HoSS Posted October 2, 2020 Author Share Posted October 2, 2020 5 plus the bumpers not enough? The form of the crossmembers and the thickness of the steel all over is way more than a 110 for example. 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted October 3, 2020 Share Posted October 3, 2020 I guess I'm just used to 110sw chassis which has 7 plus front bumper. I don't doubt the material is considerably thicker though. Mike 1 Quote Link to comment Share on other sites More sharing options...
Carloz Posted October 3, 2020 Share Posted October 3, 2020 On 7/31/2020 at 9:33 AM, Blanco said: Not sure if it is just the perspective, but that chassis is making the tow car look very small! Hoss are you thinking of dumping the merc ecu? (I take it the Dieselmeken pump is entirely mechanical) or is this just going on the spares shelf? Mmmm, it would be illegal in my country to tow that kind of trailer behind a little Duster.. 🤐 Entirely mechanical would be not my way to go: it will be ok but is never going to run perfect over the whole rev range. And always more smokey than needed. The elements can changed over between the mechanical and electronically controlled pump. 😉 6x6 Great step forward to more possibilities! I saw your plans to mount 2x 60L tanks high up behind the cabin... Very heavy and bad for stabilty and comfort. Of course the truck can handle it but watertanks are always mounted in or under the floor for a reason. I would prefer to use that space to store some light weight stuff like my spare pillows or some boxes of Cornflakes.. 😋 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 3, 2020 Share Posted October 3, 2020 @miketomcat I'm willing to bet the thing twists a lot more, Unimogs certainly do, although the radio-bodied ones are probably stiffer. Defenders are unique in not twisting (as much) although they're not as rigid as a Freelander or Ibex. 3 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 3, 2020 Share Posted October 3, 2020 3 hours ago, Carloz said: I would prefer to use that space to store some light weight stuff like my spare pillows or some boxes of Cornflakes.. 😋 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted October 3, 2020 Share Posted October 3, 2020 Can’t wait to see this new chassis come together Quote Link to comment Share on other sites More sharing options...
Jamie_grieve Posted October 4, 2020 Share Posted October 4, 2020 On 10/3/2020 at 12:36 AM, HoSS said: 3 plus the bumpers not enough? The form of the crossmembers and the thickness of the steel all over is way more than a 110 for example. I'd say there's 5 crossmembers including the rear 'bumper' as they're fully welded and an intrinsic part of the chassis. You're forgetting the rectangular crossmember across the front dumb irons. The front bumper definitely adds some stiffness too. On 10/3/2020 at 12:03 PM, FridgeFreezer said: @miketomcat I'm willing to bet the thing twists a lot more, Unimogs certainly do, although the radio-bodied ones are probably stiffer. Defenders are unique in not twisting (as much) although they're not as rigid as a Freelander or Ibex. Unimogs have C section chassis rails in common with nearly all trucks which are designed to twist, the Volvos have a box section chassis like a land rover with big flitch plates where the crossmembers are welded on to spread the load and the thick round crossmembers resist twist a lot more than the rectangular land rover ones. There's also a 5mm strip welded along the top and bottom of each rail which gives the surprisingly skinny chassis a good bit of strength. It's obviously never going to be as stiff as a short monocoque like a freelander but it's definitely stiffer and stronger than a defender chassis and can take far larger imposed loads than something like a freelander could without permanent deformation.. Also similar to the defender, the volvo body is solidly mounted although it uses hard plastic spacers rather than metal to metal. The bodies definitely add some rigidity too. On 10/3/2020 at 10:29 AM, Carloz said: Mmmm, it would be illegal in my country to tow that kind of trailer behind a little Duster.. 🤐 The volvo rolling chassis weighs 1220kg stripped like that, I'd say that whole combination is around 2 tons and well within the capabilities of the Duster. 1 Quote Link to comment Share on other sites More sharing options...
HoSS Posted October 5, 2020 Author Share Posted October 5, 2020 ^ What he said. Its well known for being very rigid, as Jamie said, more so than a Defender IMHO too. Quote Link to comment Share on other sites More sharing options...
MECCANO Posted October 5, 2020 Share Posted October 5, 2020 Proper 6x6 envy now. Whats the plated weight of a 6WD TGB. I'm guessing its over my microscopic 3.5t license? Eagerly watching this progress👍 Doe anyone know its kept... i may have to steal his axles. Just out of interest how easy is it to source volvo parts? I don't seem to beable to find 2nd hand parts let alone new. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted October 5, 2020 Share Posted October 5, 2020 On 10/3/2020 at 10:29 AM, Carloz said: I saw your plans to mount 2x 60L tanks high up behind the cabin... Very heavy and bad for stabilty and comfort. Of course the truck can handle it but watertanks are always mounted in or under the floor for a reason. I would prefer to use that space to store some light weight stuff like my spare pillows or some boxes of Cornflakes.. 😋 Biggest problem with putting the water tanks (or any other containers for liquid) is that unless you only ever drive with them either empty or brim full then they'll suffer from surge which suddenly changes the weight distribution of the vehicle. Very dangerous if you have to suddenly swerve - could easily lead to loss of control or even a roll. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 5, 2020 Share Posted October 5, 2020 44 minutes ago, geoffbeaumont said: Biggest problem with putting the water tanks (or any other containers for liquid) is that unless you only ever drive with them either empty or brim full then they'll suffer from surge which suddenly changes the weight distribution of the vehicle. Very dangerous if you have to suddenly swerve - could easily lead to loss of control or even a roll. You’d be mad not to baffle them. 1 Quote Link to comment Share on other sites More sharing options...
Carloz Posted October 5, 2020 Share Posted October 5, 2020 7 hours ago, landroversforever said: You’d be mad not to baffle them. I was not even talking about weight transfer... Which is also a smaller problem when mounted low. Quote Link to comment Share on other sites More sharing options...
