reb78 Posted September 12, 2014 Share Posted September 12, 2014 I'm looking for a decent air impact wrench. You can spend silly money on these which is what has always stopped me splashing out. What do you think of this one? https://www.machinemart.co.uk/shop/product/details/clarke-cat131-professional-heavy-duty-12-air I currently have a cheapo Aldi thing that wont pull the skin off of a rice pudding - i have to crack each nut before i can use the tool! My compressor is this one: http://www.ukhs.tv/Workshop/Air-Compressors/Dakota-14-CFM-Air-Compressor at 14CFM will it be enough? The wrench above states 18CFM but its not like the wrench will be whirring away continuously. I also have a little 2HP 50 litre compressor that i could link into the airline in tandem if that made any difference. Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted September 12, 2014 Share Posted September 12, 2014 I've just bought a Chicago pneumatics cp7732 air gun. It was £110 and it's stubby so it's ideal for some awkward jobs Quote Link to comment Share on other sites More sharing options...
henk Posted September 12, 2014 Share Posted September 12, 2014 I have 1/2" Rodcraft and CP and a 3/4" CP but to be honest I mostly use my 18V 1/2" Makita BTW450. It can change wheels of 4 cars easily on one battery. Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted September 12, 2014 Share Posted September 12, 2014 I know it's not an air gun but I've got a Snap On 6850 impact gun and this will undo more or less anything on a car. They are a lot of money, but they are well worth it. You can pick up the Snap On 3850's reasonably cheaply and that is just as good as most entry level compressors and air guns. Better in fact I would say. And I have my old one for sale... But second hand air guns and compressors are usually a good purchase in my opinion. You get more for your money than buying new. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 12, 2014 Share Posted September 12, 2014 I've got a big sealey one on recommendation of a friend. Its the same as their communal one in the workshop (Tractor dealer). I'll need to check which model it is. It does eat air and the old little 25L compressor couldn't keep up, will have to see what it will do with my new compressor. Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted September 12, 2014 Share Posted September 12, 2014 I imagine your compressor will be man enough for most stuff, where you lose it is if you have something stubborn, the pump cant keep up so you lose pressure and therefore power at the tool so it's still hammering away and getting weaker and weaker, so you have to stop wait until it's nearly up to pressure then start again so that the pump keeps running. If you let the pump trip out your back down to 6bar before it comes back in. I would recommend decent bore pipe (3/8) and check the fittings, pressure regulator etc are rated at sufficient flow as some of them can be quite restrictive. It's the pressure at the tool thats important. I have a mid range pneumatic that I hardly ever use as I have to set up the compressor, run pipes, the pipes get in the way when your working etc etc. Recently I bought a battery one, neilson I think, I use it all the time! It couldn't undo the towball on my car, but neither could the pneumatic, infact I had to jump on a meter long breaker so maybe not fair. The Rusty M12 nylocs holding the actual towbar on it did no problem. The only thing I have against it is the weight. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted September 12, 2014 Share Posted September 12, 2014 I know it's not an air gun but I've got a Snap On 6850 impact gun and this will undo more or less anything on a car. They are a lot of money, but they are well worth it. You can pick up the Snap On 3850's reasonably cheaply and that is just as good as most entry level compressors and air guns. Better in fact I would say. And I have my old one for sale... But second hand air guns and compressors are usually a good purchase in my opinion. You get more for your money than buying new. we got 2 ct7850's and a ct8810. altho there useful and quick. i still have to get the breaker bar out to many times as some stuff, like over tightened wheelbolts it just wont touch them. there more of a nut runner imho. nothing better than a 3ft bar and some muscles. ;) my compressor is 3hp 25L and it barely spins it, let alone undoes anything! so you will need a more powerful compressor. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 12, 2014 Share Posted September 12, 2014 Sealey SA6002 is the one I've got. Quote Link to comment Share on other sites More sharing options...
pw8757 Posted September 12, 2014 Share Posted September 12, 2014 I've got two Machine Mart ones, at home and at work. Both are great value for the money. I also have the Machine Mart compressors. The tool I use as well is the air powered version of the ratchet in my socket set. Again cheapo from Machine Mart and a brilliant bit of kit. I would suggest you go with your idea and best wishes! Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 12, 2014 Share Posted September 12, 2014 Ingersol Rand 2135 TiMax. Look for a decent name and compare loosening torque. 1 Quote Link to comment Share on other sites More sharing options...
Lewis Posted September 12, 2014 Share Posted September 12, 2014 Ingersol Rand 2135 TiMax. Look for a decent name and compare loosening torque. The Ingersol Rand tools are fantastic, the earlier variant of the above (the 2135QTI) can be found cheaply on ebay. I have both the 2135 1/2" and 2115 3/8" guns 1 Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted September 12, 2014 Share Posted September 12, 2014 I've always liked my ingersoll rand wrenches but when my last one wore out, the lastest replacement rand gun felt a little cluncky and unbalanced compared to the latest generation of mac tools ones I opted to buy 2 different 1/2 wrenches from mac to cover the range of tasks i carry out day to day, my general use wrench is the AWP050C this is a compact 1/2 wrench its very short (about the same length as a 3/8) very fast, light and unless something it FT it doesn't struggle to undo it. My other 1/2 wrench is the Mac AWP050 this is very powerful, nicely balanced a touch heavier than my previous 2135 Rand wrench but a lot faster and quieter. The AWC050C is a really really nice tool to use, its compact size (with marginally less power than a Rand 2135) is a huge bonus. Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 13, 2014 Author Share Posted September 13, 2014 we got 2 ct7850's and a ct8810. altho there useful and quick. i still have to get the breaker bar out to many times as some stuff, like over tightened wheelbolts it just wont touch them. there more of a nut runner imho. What do these folks have that undo crank bolts with these impact wrenches? What you say above is my general experience of them so far too. Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted September 13, 2014 Share Posted September 13, 2014 That should do it https://www.google.co.uk/shopping/product/5809657148062233396?q=air+impact+wrench+1%22&client=safari&hl=en&biw=320&bih=460&ei=qy0UVP-VE-XA7AaypIGYAg&ved=0CMEDEKYrMBE Quote Link to comment Share on other sites More sharing options...
discomikey Posted September 13, 2014 Share Posted September 13, 2014 go for ingersoll rand, by far the best i highly reccomend the 2135TImax, where it is expensive, it is 50x better than my machine mart gun and uses less air so less compressor noise too Quote Link to comment Share on other sites More sharing options...
Scooby Jim Posted September 13, 2014 Share Posted September 13, 2014 These are mine old school Chicago Pneumatic. CP734 - 1/2" Torque rating 576Nm (425ft.lbs) CP772 - 3/4" Torque rating 1356Nm (1000.lbs) An air chisel/hammer, and an air drill. My spray stuff and die grinders live in a different drawer.The air compressor I run now is a SIP jobbie 14CFM and tbh I'm yet to have it struggle.I did have an Atlas Copco TE22E but the conrod seized due to the oil screw on the pump getting broken. Quote Link to comment Share on other sites More sharing options...
Jon White Posted September 13, 2014 Share Posted September 13, 2014 I have the cp 734h which is the one I use the most as it's man enough for most things. I also have an ingersoll rand 2135ti which is just awesome, but noisy. Save your money and buy some thing decent, and don't tiddle about with anything with clarke written on it. The first one I had wouldn't even undo car wheel nuts that I'd torqued with a torque wrench to 50ftlbs only seconds before! Jon Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 13, 2014 Author Share Posted September 13, 2014 Thanks chaps. Been looking at some secondhand ones. Some state a torque range and a maximum torque. I presume the torque range is what it actually puts out in use (?), so what is the meaning of the max torque figure? Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted September 13, 2014 Share Posted September 13, 2014 You can adjust the torque on some of them so you don't over tighten smaller stuff. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted September 14, 2014 Share Posted September 14, 2014 I have a bit of inside knowledge to share on this matter. Seeing as my job these days is servicing and repairing Air tools, and especially impact wrenches. First and foremost the power to break a heavy bolt loose is almost solely in the impact wrench, only marginally in the compressor. With my AC compressor on the 80" running just at high idle I can break loose a crank bolt no problem with either my Ingersoll-Rand 1/2" or my KS-Tools Monster 1/2". However with a small compressor you obviously only have maximum torque for a couple of rotations, where as a big compressor will let you keep hammering without having to let the compressor air up. The different designs of hammer systems is sort of a matter of taste. Each have their merits so I don't really have any specific favorites there although I will say that generally the Twin Hammer design seems to have a bit more breaking power without having to spin as fast which is kind of nice if your not in a rush and like to see your nuts and bolts flying around the workshop like little Frisbee's Though this is also one of the systems that I most often see failures is if the material being used is not of top quality. The only systems that really suffers from wear with the result of gradual power loss is the Pin Clutch system. Hope this is of some help Quote Link to comment Share on other sites More sharing options...
zim Posted September 14, 2014 Share Posted September 14, 2014 The IR 2135qti is a very light very nice gun. Watch ebay they come up quite often. We use both IR and snap on here at work..... The snap on one is currently in bits ? Quote Link to comment Share on other sites More sharing options...
yalan Posted September 14, 2014 Share Posted September 14, 2014 Also have a 2135qtiMax. Excellent tool if you've got the air. Quote Link to comment Share on other sites More sharing options...
discomikey Posted September 15, 2014 Share Posted September 15, 2014 Also have a 2135qtiMax. Excellent tool if you've got the air. average air consumption 5cfm, most compressors will easily do that, max air consumption @load is 24cfm. The figures on the clarke gun i have are similar, except with 1/3 if not less of the max torque. as a result you are hammering for longer and use much more air than the IR gun which will instantly whiz it off most of the time without kicking the compressor in. 90% of the time you are either doing wheelnuts, or that one stubborn bolt. Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 16, 2014 Author Share Posted September 16, 2014 Anyone any opinions on the IR 2130 XP? http://www.ingersollrandproducts.com/eu-en/products/tools/impactools/maintenance-automotive-impactools/1-2-drive/2130xp These are a little cheaper than the 2135 qti, but they still seem to have good torque figures? Edit: answered it myself. I guess max torque in reverse 816nm vs 1054nm and working range 34-474nm vs 64-746nm answers the question. Quote Link to comment Share on other sites More sharing options...
Lewis Posted September 16, 2014 Share Posted September 16, 2014 Never used one, but seriously - get the 2135qti. Even a preloved one Quote Link to comment Share on other sites More sharing options...
