Nonimouse Posted September 27, 2022 Share Posted September 27, 2022 45 minutes ago, landroversforever said: I seem to remember that being a thing too. It's doable but a pita Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted September 27, 2022 Share Posted September 27, 2022 1 hour ago, Daan said: I personally prefer a 300 for reasons of availability and price of parts. And easy conversion. Not aware of the head being more prone to problems? Heads are available for a 300 for surprisingly little money: China head: Cylinder Head+Valves ERR5027 for Land Rover Defender 2.5L 300tdi Discovery NEW | eBay London Head: LAND ROVER DEFENDER 300TDI CYLINDER HEAD BUILT UP NEW - LDF500180COM | eBay I am not 100%, but I think you can fit a 300 head on a 200? Daan 300's were always more subject to head cracking - the quality of the castings was much lower. Made in turkey to reduce the engine costs down Although still a good engine, they were Less fuel efficient More prone to overheating and damage from over heating Less easy to tune Far more unforgiving of poor injector maintenance Far more susceptable to high EGT Buy we are talking small issues really. the Overheating was down to the pump position. Far less water loss created problems and the water jacket was much smaller than the 200 anyway They are both amazing engines that really don't get appreciated enough Edited to point out the inherant weekness in the 300 oil pump and vacuum pump 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 28, 2022 Author Share Posted September 28, 2022 15 hours ago, Daan said: I am not 100%, but I think you can fit a 300 head on a 200? Daan I believe you need to fit the pistons too. The bottom line is I have a 200 fitted, I like the 200, there's a 200 in the wife's 110, the 200 has better mpg than anything else, the 300 is not enough better to warrant the agro and I don't have the money to do a conversion of any type. So I'll be repairing and keeping a 200 TDI. Mike 2 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 28, 2022 Author Share Posted September 28, 2022 Pulled the head off the low oil pressure engine last night and gave it a quick clean up ready to go on. Worryingly three of the push rods on that engine were bent but it ran fine bar low oil pressure. I'm pretty sure I've not had that head off before but did check the valve clearance a while ago. Mike 1 Quote Link to comment Share on other sites More sharing options...
western Posted September 28, 2022 Share Posted September 28, 2022 possibly had a timing belt break at some point, just swap the bent rods for known straight ones, the pushrods bent so the vaalves/piston only touch without wrecking eachother. 2 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 28, 2022 Author Share Posted September 28, 2022 1 minute ago, western said: possibly had a timing belt break at some point, just swap the bent rods for known straight ones, the pushrods bent so the vaalves/piston only touch without wrecking eachother. Yeah that was my thought I guess the previous owner just changed the belt and didn't check them. Not worried as that is the engine I'm going to rebuild anyway. Mike 3 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 29, 2022 Author Share Posted September 29, 2022 Well I've swapped the head tonight but haven't had chance for a good run (it'll get one on the way to work in the morning) but fingers crossed it seems ok. I have found the crack in the other head so that's good I have something to pin the problems on but a shame the heads a right off. The crack is the vertical line above the valve stem and just to the left of the valve guide in the picture. Mike 2 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 30, 2022 Share Posted September 30, 2022 Well found, at least you have closure on it. Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted September 30, 2022 Share Posted September 30, 2022 Not neccessarily a right off. A number of engine specialist companies are using a cemical sealant (much like liquid metal, to fix cracks in heads. Mainly engines like TD5's, but it would beworth asking a few 1 Quote Link to comment Share on other sites More sharing options...
Daan Posted September 30, 2022 Share Posted September 30, 2022 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 30, 2022 Share Posted September 30, 2022 Now you're being a pendant! 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 30, 2022 Author Share Posted September 30, 2022 Dyslexic. yes I did need to look it up. Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted September 30, 2022 Share Posted September 30, 2022 2 hours ago, miketomcat said: Dyslexic. yes I did need to look it up. Likewise Quote Link to comment Share on other sites More sharing options...
markyboy Posted October 3, 2022 Share Posted October 3, 2022 On 9/30/2022 at 4:01 PM, Daan said: Thanks, Daan, you 'went' where I didn't dare 🙊 🤣 Quote Link to comment Share on other sites More sharing options...
TSD Posted October 3, 2022 Share Posted October 3, 2022 Never mind the excuses and recriminations for poor use of english, what I still want to know is, does the engine now perform correctly? 2 Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 3, 2022 Share Posted October 3, 2022 On 9/30/2022 at 4:15 PM, FridgeFreezer said: Now you're being a pendant! Well he's certainly being a dangly thing I suppose.... 😛 Quote Link to comment Share on other sites More sharing options...
Popular Post miketomcat Posted October 3, 2022 Author Popular Post Share Posted October 3, 2022 27 minutes ago, TSD said: Never mind the excuses and recriminations for poor use of english, what I still want to know is, does the engine now perform correctly? It certainly seems to be performing as it should.............. For now. Seems to be smoking less too. Mike 6 Quote Link to comment Share on other sites More sharing options...
Daan Posted October 3, 2022 Share Posted October 3, 2022 4 hours ago, markyboy said: Thanks, Daan, you 'went' where I didn't dare 🙊 🤣 We promote the correct use of the English language on LR4x4. Interesting it has to come from a Dutch man, who to all intents and purposes, is still learning! Mike, I am glad to hear your car is working again. Daan 2 Quote Link to comment Share on other sites More sharing options...
markyboy Posted October 3, 2022 Share Posted October 3, 2022 2 minutes ago, Daan said: We promote the correct use of the English language on LR4x4. Interesting it has to come from a Dutch man, who to all intents and purposes, is still learning! Daan It appears that the main topics, traditionally taught in schools, have become less important since I was at school (admittedly a long time ago). Of course, dyslexia is much more widely diagnosed/recognised now. I had never heard of it until long after I left school. Mark Quote Link to comment Share on other sites More sharing options...
miketomcat Posted October 3, 2022 Author Share Posted October 3, 2022 3 hours ago, Daan said: We promote the correct use of the English language on LR4x4. Interesting it has to come from a Dutch man, who to all intents and purposes, is still learning! Mike, I am glad to hear your car is working again. Daan Whilst I agree with the sentiment and try my best to use correct spelling and grammar. I think publicly shaming people is not the way to do it, a simple PM with an offer to change or allow it to be changed would suffice. I am thick skinned enough to not care what people think and don't take offense but others might not be so inclined. End of subject! Mike 2 Quote Link to comment Share on other sites More sharing options...
Daan Posted October 3, 2022 Share Posted October 3, 2022 Sorry Mike, it was meant as a joke. Daan 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted October 3, 2022 Share Posted October 3, 2022 offense.... Totally not poking or anything. Spelling on this forum is excellent by interweb standards and any slips often add a touch of humour too- hell, I've got some used Heras fencing which has a printed safety sign saying ASSEMBLEY POINT on it that makes me smile when I notice it every time. ..anyway, I'm glad you have made some progress Mike and things look stabilised, get that spare engine stripped for a look see . Steve Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 3, 2022 Share Posted October 3, 2022 1 hour ago, steve b said: Spelling on this forum is excellent by interweb standards That's so long as Nige hasn't been on the vino! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 4, 2022 Share Posted October 4, 2022 9 hours ago, Bowie69 said: That's so long as Nige hasn't been on the vino! Or sober! Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 7, 2023 Author Share Posted January 7, 2023 Well this is nice. Bang and a box full of neutrals..... Mike 6 Quote Link to comment Share on other sites More sharing options...
