deep Posted September 29, 2022 Share Posted September 29, 2022 2 hours ago, Nonimouse said: Until the engine stops - which is where this came from Which is why I have carried a Tirfor for years - and had occasion to use it! 1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted September 29, 2022 Share Posted September 29, 2022 Actually doing a bit of reading on this following my initial comment it seems you can get more efficient setups doing electrical -> hydraulic rather than direct electric but it's not straight forward. It's all down to sizing of the motors etc., and usually electric -> hydraulic can win over direct electric if there are multiple motors / axis involved. The (simplified) reasoning being that each movement needs to be sized for it's peak load thus making it bigger than it might need to be in most normal operation and thus less efficient normally. However if you use hydraulics the stuff averages out over the axes so you can be more efficient in your coupling of motor to pump. This is usually when there's lots of gearing and multiple motors involved so I don't think it holds true in our simple example of a winch setup. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted September 30, 2022 Share Posted September 30, 2022 12 hours ago, deep said: Which is why I have carried a Tirfor for years - and had occasion to use it! Probably not an appealing fallback if you're competing rather than just self recovering. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 30, 2022 Share Posted September 30, 2022 13 hours ago, deep said: Which is why I have carried a Tirfor for years - and had occasion to use it! We ran hydro in the racers over several events in very nasty stuff - a well maintained engine shouldn't stop unless you're upside-down or completely underwater, and in that eventuality there's the bad old method of Hi-Lift or most likely another vehicle to pull you over/out. The rest of the time, adding weight & complexity "just in case" is how people end up with 90's that weigh as much as a Unimog and get more stuck in the first place... 2 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted September 30, 2022 Share Posted September 30, 2022 I love this thread derailment. I've a 101 that has had the winch removed. This was in the side on the chassis rail, and powered by a take off from the transfer box. Unique to the 101, this was a shaft from the side of the transfer box. I've located a winch, but can't find the transfer box kit. So I'm thinking of other ways of powering the winch.  I've 24v electrics and could probably find a standard PTO kit. What would be a smart option? Simple (very), repairable, affordable? Quote Link to comment Share on other sites More sharing options...
elbekko Posted September 30, 2022 Share Posted September 30, 2022 38 minutes ago, FridgeFreezer said: a well maintained engine shouldn't stop unless you're upside-down or completely underwater Or you stall it and it won't restart because the starter has been sitting underwater in a swamp for 24 hours... 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 30, 2022 Share Posted September 30, 2022 30 minutes ago, Gazzar said: Â I've 24v electrics and could probably find a standard PTO kit It will depend on what the gearbox is like on the winch, my suspicion would be you'd need to gear it down a lot to get a 24V motor working on it. An 8hp Bowmotor 2 plus could be enough, but the gearing issue persists. Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted September 30, 2022 Share Posted September 30, 2022 1 hour ago, Gazzar said: I love this thread derailment. I've a 101 that has had the winch removed. This was in the side on the chassis rail, and powered by a take off from the transfer box. Unique to the 101, this was a shaft from the side of the transfer box. I've located a winch, but can't find the transfer box kit. So I'm thinking of other ways of powering the winch.  I've 24v electrics and could probably find a standard PTO kit. What would be a smart option? Simple (very), repairable, affordable? What you need is a SIdewinder. Weird winch. Actually suprisingly effective. Rare as a rare thing. Especially over here https://forum.ih8mud.com/threads/vic-hickey-sidewinder-winch-refurb.938593/ Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 30, 2022 Share Posted September 30, 2022 2 hours ago, elbekko said: Or you stall it and it won't restart because the starter has been sitting underwater in a swamp for 24 hours... Again, at that point there's bigger problems anyway. 1 Quote Link to comment Share on other sites More sharing options...
elbekko Posted September 30, 2022 Share Posted September 30, 2022 9 minutes ago, FridgeFreezer said: Again, at that point there's bigger problems anyway. That I'm not disputing But the discussion started out as an electric back-up to the PTO/engine driven pump, which I do think can be very useful. 1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted September 30, 2022 Share Posted September 30, 2022 2 hours ago, Gazzar said: What would be a smart option? Simple (very), repairable, affordable? Phone Bob because he probably has one lying around the yard Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 30, 2022 Share Posted September 30, 2022 1 hour ago, elbekko said: But the discussion started out as an electric back-up to the PTO/engine driven pump, which I do think can be very useful. I can't help but think driving the winch electrically and using your existing alternator / battery as a "backup" might work out the easiest way round to cover that scenario But then winch challenge logic is not always normal logic Quote Link to comment Share on other sites More sharing options...
Gazzar Posted September 30, 2022 Share Posted September 30, 2022 2 hours ago, Ed Poore said: Phone Bob because he probably has one lying around the yard Not so far..... Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted September 30, 2022 Share Posted September 30, 2022 5 hours ago, Gazzar said: Not so far..... He will have one - he'll have just forgotten where it is, or the fact that he has one. After all everyone on the Cummins forum are ranting and raving about 1:1 ratio and he's had 0.9 ratio transfer boxes festering in his yard for decades. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 30, 2022 Share Posted September 30, 2022 3 minutes ago, Ed Poore said: he's had 0.9 ratio transfer boxes festering in his yard for decades. It needs found so it can fester on Sid........lol Just winding you @Ed Poore  regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Gazzar Posted September 30, 2022 Popular Post Share Posted September 30, 2022 10 hours ago, Nonimouse said: What you need is a SIdewinder. Weird winch. Actually suprisingly effective. Rare as a rare thing. Especially over here https://forum.ih8mud.com/threads/vic-hickey-sidewinder-winch-refurb.938593/ Probably, but not convinced. Avoiding the problem of finding a rare, but occasionally available winch, by picking a rare, but seldom available winch, isn't working for me . . . 1 4 Quote Link to comment Share on other sites More sharing options...
Snagger Posted November 29, 2022 Share Posted November 29, 2022 Had my first experience of an EV yesterday.  One of the tall Teslas.  They are massively overrated.  Apart from the godawful touch screen instead of real, tactile controls, the door latches use small electric switches to open the door from the inside, which is as costly as it is dangerous and they are hard to find if you don’t know the cars, the seats are far too hard for long journeys and the noise at motorway speeds is no different to an ICE vehicle because of the tyre noise, even on their special tyres.  Other EVs are probably a better option.  Late Teslas boast very good range, but that’d be heavily reduced here because of the continuous use of AC.  Their range may still be greater than almost all competitors, but that is never the only consideration.  I was never a Tesla fan, but this was still disappointing. 3 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted November 29, 2022 Share Posted November 29, 2022 1 hour ago, Snagger said: Had my first experience of an EV yesterday.  One of the tall Teslas.  They are massively overrated.  Apart from the godawful touch screen instead of real, tactile controls, the door latches use small electric switches to open the door from the inside, which is as costly as it is dangerous and they are hard to find if you don’t know the cars, the seats are far too hard for long journeys and the noise at motorway speeds is no different to an ICE vehicle because of the tyre noise, even on their special tyres.  Other EVs are probably a better option.  Late Teslas boast very good range, but that’d be heavily reduced here because of the continuous use of AC.  Their range may still be greater than almost all competitors, but that is never the only consideration.  I was never a Tesla fan, but this was still disappointing. I've driven a few now. Liked none of them. Pretty much for the same reasons...  Love our new work XC90 Hybrids though. 2 Quote Link to comment Share on other sites More sharing options...
Snagger Posted November 30, 2022 Share Posted November 30, 2022 The unequivocal, fervent and blind adulation some people have for Tesla is really just blind brand-love.  It’s the same with the overpriced, overrated Apple products.  At least the bulk of us on this forum are well aware of the shortcomings of our favoured brand, despite our loyalty, and many of us just have a love for a certain model or era from the company, not a fetish about everything they make. 2 1 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted November 30, 2022 Share Posted November 30, 2022 47 minutes ago, Snagger said: The unequivocal, fervent and blind adulation some people have for Tesla is really just blind brand-love.  It’s the same with the overpriced, overrated Apple products.  At least the bulk of us on this forum are well aware of the shortcomings of our favoured brand, despite our loyalty, and many of us just have a love for a certain model or era from the company, not a fetish about everything they make. Totally agree with this. Apple and Tesla are both on the list of companies I would never pay a penny of my own money to. Not driven an electric car yet but a mate has a Porsche Taycan on order and it will be interesting to compare it to our Panamera given they are both the same brand Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted November 30, 2022 Share Posted November 30, 2022 I have an iPhone 12 for work. Utterly useless. Made worse by being on O2 and being a Civil Service protected phone. Just utterly, utterly useless. Good job I've got my cheap chines ruggedised personal phone Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 30, 2022 Share Posted November 30, 2022 1 hour ago, Snagger said: The unequivocal, fervent and blind adulation some people have for Tesla is really just blind brand-love.  It’s the same with the overpriced, overrated Apple products.  At least the bulk of us on this forum are well aware of the shortcomings of our favoured brand, despite our loyalty, and many of us just have a love for a certain model or era from the company, not a fetish about everything they make. I don't have a fetish for everything they make, but for me my various iPhones over the years and my ipad just work. All the time, zero issues, zero fuss. Yet family with all sorts of brands of android stuff are always having problems with them, even the tech savvy folks. I see zero point in their laptop and desktop options unless you're doing lots of video editing as they do seem to work better for that. I do agree with the Tesla thing though! Several I know with them and as far as I can see the only benefit to a tesla is the charge network. Build quality seems terrible for a start! 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 30, 2022 Share Posted November 30, 2022 1 hour ago, landroversforever said: I see zero point in their laptop and desktop options unless you're doing lots of video editing as they do seem to work better for that. Excellent for a web developer, as in my case. 1 Quote Link to comment Share on other sites More sharing options...
Peaklander Posted November 30, 2022 Share Posted November 30, 2022 I am not an Apple "nut" but I do have an iPhone and a Macbook Air. The phone just works, as Ross says and as for the MacBook it was utterly amazing to make the jump from a Windows Sony Vaio in 2011. I used to travel for work, a lot and needed to snatch moments to work on stuff. With the MacBook I could open it and be typing within a few seconds. I could close the lid, shove it in my bag and move on, without worrying that it hadn't hibernated properly. It was just brilliant. That's before i mention the backlight on the keyboard and the track pad that really did function without a mouse. It was in a totally different league to the Vaio / XP environment. The Apple model of hardware and software design, I thought, is supposed to make for far better support and seamless upgrading. I haven't paid for a new Operating system or upgrade, except when I moved to a newer MacBook about four years ago. I don't have recent Windows experience (although I do still run some old software on the Vaio) but I do still love the Mac environment and can't imagine going back. Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted November 30, 2022 Share Posted November 30, 2022 I would point out that most of the utterly uselessness of my iPhone is the carp battery life in the cold, medium cold , very warm and hot; the lack of IP68 integrity and mostly the fact that it rebels against all the carpy software that we are forced to use as a government organisation. It takes great pictures, when the battery is working. I can see a place for iPhones but not within an outside environment or as part of the equipment issued to a compnay that won't fork out for better software. Android works with carpy software and unstable unions betoween said carpy software. It's cheap, so if and when it breaks, who cares. As my out of work life is just like my work life, same goes there 1 Quote Link to comment Share on other sites More sharing options...
