You could try Fieldensotrltd.co.uk , not far from me and have been in the flotation tyre trade since they brought the first Terra-tyres into the UK. Mainly AG/Plant but they might tack yours onto an import order?
Off-roaded with the founder of the business in the '80's
Steve
2 minutes ago, dangerous doug said:
They are about but they are a dumper tyre. I dont know what they’re called but they’re a less open chevron pattern. Or you can try and find what The zil 131 use
https://mortarinvestments.eu/catalog/item/zil-131-12-20?
or there are things like the Michelin xzl
IIRC These are also a michelin but I forget what they’re called
i think these are "XCL"
HardAsNails I think?
As discussed before, Sid needs a tyre suitable for the weight of the truck (which Stephen still needs to confirm ;) ) Current tyres have massively stiff sidewalls which on a <2 ton rig don't want to flex..... even at 5PSI.
  • Like 1
Like the look of them but ideally I want light truck tyres where the side walls will flex Sid is not as heavy as we were expecting......lol
Regards Stephen
I thought I had at 1740kg
Regards Stephen
Had a bit of a hunt of my usual suspects, short story is.... for anything on a 20" rim they tend to be max 35" tyres, if you want 37" or over you really ought to drop down to a 17.... then you may stand a chance of getting something this side of the pond.
Maxxis, Milestar, Goodrich are all pretty much the same in this respect, I guess it comes down to carcass availability.
17 minutes ago, Bowie69 said:
Were you not waiting to get some floor scales? Or am I misremembering?
Not floor scales, I was looking to get a smaller scale to get a truer weight of axles, the scale I used for the body was physically too big to get what I would consider accurate axle weights, it's fairly moot though as I was very happy with how the Fox shockers performed
Regards Stephen
My findings as well unfortunately, I wonder if it is possible to find anything in Europe....?
Regards Stephen
Just now, Bowie69 said:
I had looked at them but showing no stock, I'm in no rush if I'm patient something will come up, it usually does
Regards Stephen
Regards Stephen
Managed to find one so far, also a stupid looking tyre sadly:
https://www.pneus.be/nl/nitto-mud-grappler-37x13.50-r20-121p--2793602
Nothing bigger than that yet, unless Ag stuff.
Might also be worth searching in metric? 40x13.5R20 is about 345/75R20.
A long time ago now Dirtydiesel lent me a set of 255r16 XZL's and they were... not good.
Probably last a million miles on a Land Rover and bullets would bounce off them, but they were definitely designed for something weighing 7.5t or more, even when one of my rims sprang a leak and let all the air out the truck was still sitting level on 0psi :lol: and they didn't have much bite off-road at all, I'd reckon BFG AT's would have done better!
Steve
One more time
Steve
  • Thanks 1
25 minutes ago, TD5toV8110 said:
The obvious solution for Stephen is.....
Just make your own tyres! 🤣🤣🤣
Cheers
Dave🤪
Do not tempt the man...  He wil just make some mold's and start building carcasses for everybody who would like a set . Sid wil never spring to life again
  • Haha 1
Cheers
Dave🤪
For heavens sake don't stir them up Dave.......lol
Regards Stephen
  • Haha 1
I mean I have some regroovable 48" tyres available... but I dunno how much they would flex when the vehicle weighs about as much as the tyre is rated for 🤣
  • Haha 1
