Snagger Posted September 15, 2022 Share Posted September 15, 2022 SimonR’s X-Deflex would be stiff enough to give significant help, but the tyres are still going to compress a lot. It’d really need a similar stiff front anti roll bar and perhaps some (eughhh) 18”rims with lower profile tyres to cope. 1 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted September 15, 2022 Share Posted September 15, 2022 I did a driving course for some of the RAF lads down at RNAS Yeovilton, back awhile. They were driving 130's with single cabs and long quadtech bodies on. Full of electronic jamming kit. Then on the cab roof was a roof basket with 250kgs of mast sections, for the telescopic mast mounted on the back. I was working for LRE at the time, so using their site. I will admit to chickening out on the track up to the site! Truly awful and blooming dangerous. In my report to their CO, I recommended that they never go off the runway... 1 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 15, 2022 Share Posted September 15, 2022 3 minutes ago, Snagger said: SimonR’s X-Deflex would be stiff enough to give significant help, but the tyres are still going to compress a lot. It’d really need a similar stiff front anti roll bar and perhaps some (eughhh) 18”rims with lower profile tyres to cope. I found that making everything stiffer doesn't help beyond a certain point, physics wants it to tip over so all you're doing is moving the lean from the suspension to the tyres, when that runs out you are going to lift a wheel / tip over instead. The 127 handles a lot better since we softened the springs, sure it may lean a tad more but it does it on the springs in a controlled manner rather than being stiffer and feeling like a bump halfway round a corner could destabilise the vehicle and bounce you onto 2 wheels. If you want it to actually be less tippy, removing weight from high up / adding weight low-down is about all you can do - we've minimised it as far as possible but it's never going to handle like an MX5. Interestingly the 109 actually does feel like a sports car by comparison as it has weight low-down and much wider track even though it's still a tall vehicle. 2 Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 15, 2022 Share Posted September 15, 2022 Yep, ultimately it’s all about squashing that pyramid. Quote Link to comment Share on other sites More sharing options...
Popular Post Eightpot Posted September 15, 2022 Popular Post Share Posted September 15, 2022 My Rangie ambance used to handle like a mini but springs were way too harsh even sat with full weight at 3 ton - stiffest ones OME made. I put softer, but still HD OMEs on this time round - way nicer off road but has me clenching my backside round most bends - I tried everything to move CoG, repacked, shifted weight, even got rid of heavy clothes! Oddly the best improvement I've found is to run with full fuel tanks, really counterbalances the weight and sits much nicer in a bend. Just makes me weep everytime I have to fill it 😭 5 Quote Link to comment Share on other sites More sharing options...
elbekko Posted September 15, 2022 Share Posted September 15, 2022 Would be nice if it was easy to retrofit the D2's ACE system. That would solve most of the leaning issues. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 15, 2022 Share Posted September 15, 2022 1 hour ago, Snagger said: SimonR’s X-Deflex would be stiff enough to give significant help, but the tyres are still going to compress a lot. It’d really need a similar stiff front anti roll bar and perhaps some (eughhh) 18”rims with lower profile tyres to cope. Then I think you'd be into the realms of bending the arms. @TJN did on his 130. Quote Link to comment Share on other sites More sharing options...
Popular Post Bowie69 Posted September 15, 2022 Popular Post Share Posted September 15, 2022 Added benefit of having the lean in the suspension is that you have the dampers helping to control things -the tyres are not well damped at all, so will react poorly on a bump. After all, it's not the lean that tips these things over, it's the bump while leaning that often does it. 5 Quote Link to comment Share on other sites More sharing options...
Escape Posted September 15, 2022 Share Posted September 15, 2022 The problem with lean in the suspension is it will move the CoG to the outside and possibly up, more so if the CoG is significantly higher than the axles or roll center. So while I agree it isn't a problem in itself and gives better damping control and feel, it will reduce traction. Rolling from one side to the other can be quite interesting during a series of opposing bends as well because the weight is constantly shifting side to side. Clearly illustrated when you see a Mini tackle the same corners as a 2CV on a classic car run. 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 15, 2022 Share Posted September 15, 2022 27 minutes ago, Escape said: Clearly illustrated when you see a Mini tackle the same corners as a 2CV on a classic car run. You can roll either if you try hard enough - the difference is how many wheels you keep on the ground the rest of the time. 3 Quote Link to comment Share on other sites More sharing options...
deep Posted September 15, 2022 Share Posted September 15, 2022 9 hours ago, FridgeFreezer said: You can roll either if you try hard enough - the difference is how many wheels you keep on the ground the rest of the time. Suspension travel on that 2CV is impressive! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 15, 2022 Share Posted September 15, 2022 2 hours ago, deep said: Suspension travel on that 2CV is impressive! They’re like that stock! 1 Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted September 16, 2022 Share Posted September 16, 2022 20 hours ago, landroversforever said: They’re like that stock! I've never driven one, but used to have a friend who's girlfriend drove one. He reckoned you went nowhere fast in it, but you always had a lot of fun getting there. Quote Link to comment Share on other sites More sharing options...
western Posted September 16, 2022 Share Posted September 16, 2022 I've seen 2cv racing at brands hatch, the lean in the corners is scarey, wouldn't want to be on the inside. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 17, 2022 Share Posted September 17, 2022 On 9/16/2022 at 7:57 PM, western said: I've seen 2cv racing at brands hatch, the lean in the corners is scarey, wouldn't want to be on the inside. Friend crews for one that does endurance racing! Hilarious things to watch. On 9/16/2022 at 7:41 PM, geoffbeaumont said: I've never driven one, but used to have a friend who's girlfriend drove one. He reckoned you went nowhere fast in it, but you always had a lot of fun getting there. Chris Harris and Andrew Frankel have them and love them to pieces. And they’ve driven some nice metal. Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 18, 2022 Share Posted September 18, 2022 On 9/16/2022 at 12:21 AM, deep said: Suspension travel on that 2CV is impressive! That is why the Royal Marines trialled them for helicopter ferried platforms before the “Air portable” (Lightweight) was developed by LR. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 18, 2022 Share Posted September 18, 2022 On 9/16/2022 at 7:41 PM, geoffbeaumont said: I've never driven one I used to have one with a V4 engine in it, good fun.....Regards Stephen Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 19, 2022 Share Posted September 19, 2022 A 2CV was the car of choice for my teachers in the seventies 😄 Mo Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 19, 2022 Share Posted September 19, 2022 Has anyone made a camper out of a 2cv? Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted September 19, 2022 Share Posted September 19, 2022 16 minutes ago, reb78 said: Has anyone made a camper out of a 2cv? 'Thousands' would only be a slight exaggeration. See https://www.google.com/search?client=firefox-b-d&q=2cv+camper Regards. Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 19, 2022 Share Posted September 19, 2022 1 hour ago, David Sparkes said: 'Thousands' would only be a slight exaggeration. See https://www.google.com/search?client=firefox-b-d&q=2cv+camper Regards. Ah. Excellent. Well on topic then. Lets see if they all get ripped to bits on this thread too.... 1 Quote Link to comment Share on other sites More sharing options...
Escape Posted September 20, 2022 Share Posted September 20, 2022 9 hours ago, reb78 said: Ah. Excellent. Well on topic then. Lets see if they all get ripped to bits on this thread too.... They're too small. They'll never make it uphill. They're always overloaded. They're French so you need metric tools. They're aircooled so you'll need a fuel burning heater all the time. They're too top heavy and soft sprung so they'll tip over. And little kittens will die. How's that for starters? 😈 Not really a fan, don't mind seeing them around but wouldn't want to drive one. 3 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 20, 2022 Share Posted September 20, 2022 4 minutes ago, Escape said: They're French so you need metric tools Better than working on a P38 engine where you need metric and imperial with different threads present even on the same casting(!) Quote Link to comment Share on other sites More sharing options...
Escape Posted September 20, 2022 Share Posted September 20, 2022 6 minutes ago, Bowie69 said: Better than working on a P38 engine where you need metric and imperial with different threads present even on the same casting(!) Not the mention the studs that are metric thread on one side and imperial on the other. 😉 2 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted September 20, 2022 Share Posted September 20, 2022 Sorry: 2 Quote Link to comment Share on other sites More sharing options...
